Introduction: Raspberry Pi Pico Racing Wheel
Raspberry Pi Pico is interesting board for making interesting projects from programming. I use Pico board as mouse in Euro Truck Simulator 2. Using potentiometer I measure analog values and convert to movement of mouse in my computer.
Step 1: BOM
You will need:
1. Raspberry Pi Pico
2. potentiometer 1 kOHM
3. breadboard & dupont cables
4. 100 ohm resistor for 100 % sure for protecting analog pin
For sure, you can check potentiometer pins, if resistance betweem 1 and 3 pins is 1 kohm always.
Step 2: Wiring
Wiring is simple:
1. GND (3 pin on Pico)
2. analog pin on 10 pin Pico
3. VCC = 3,3 V on 5 pin Pico
For sure, you can add in serial to analog pin 100 ohm resistor.
Step 3: Software and Code
You will need to install:
1. Circuit Python from Adafruit
https://learn.adafruit.com/welcome-to-circuitpython/installing-circuitpython
2. adafruit_hid folder from:
https://learn.adafruit.com/circuitpython-essentials/circuitpython-hid-keyboard-and-mouse
3. MU Editor (optional):
https://learn.adafruit.com/getting-started-with-raspberry-pi-pico-circuitpython/installing-mu-editor
Code is simple, you will need only create code.py and copy this code (code.py file is created as default).
Be care of wrong blanks. Python language use blank with proper size (use TAB if errors in code)!
import time import usb_hid from adafruit_hid.mouse import Mouse import board import analogio mouse = Mouse(usb_hid.devices) time.sleep(1) potentiometer = analogio.AnalogIn(board.GP26) y=0 while True: x=int(potentiometer.value/200) if abs(y-x)>2: print("posun "+str(y-x)) mouse.move(-(y-x)) print(x) y=int(potentiometer.value/200) time.sleep(0.2)
