Raspberry Pi Turn On/Off With Any Remote Control
Intro: Raspberry Pi Turn On/Off With Any Remote Control
Controlling power to the Raspberry Pi with an IR remote.
STEP 1: Requirements
- 1x Raspberry Pi
- 1x 5V power source (typically the wall adapter that comes with Raspberry Pi kits)
- 1x USB 2.0 to Micro B Cables
- 1x IRP1000 - Remote Control 1-CH 5V Relay USB Power Control Raspberry Pi
Found here on Amazon: IRP1000 - 1x IR remote control
STEP 2: Setup
*Recommended to not have anything plugged in at output side during programming. When plugging 5V source to input side, 5V is active on output side.
- Plug 5V source to the wall outlet
- Plug the Micro USB end to the input side of IRP1000
- Press and hold the learning button
- Wait for the LED to flash 3 times
- Press any button on the remote control you wish to use
- Programming complete
- Plug the Micro USB cable into the Raspberry Pi and the other end to the output side of IRP1000
STEP 3: Usage
The power output to the Raspberry Pi is toggled on or off with a single button press on the remote used to program the IRP1000. If the red LED is on, then IRP1000 shuts off the 5V on the output side. If the red LED is off, then IRP1000 turns on the power on the output side.
10 Comments
dlong1119 5 years ago
Is there anywhere to still buy the IRP1000? Amazon is showing that it's unavailable and this would be the perfect solution to control my TV bias lighting from my Harmony remote, as my TV's USB power is always on.
raja26 6 years ago
Will this not damage the SD or the Pi itself? Since this is not a proper shutdown.
JamesB573 6 years ago
I'm thinking this setup would be more for turning the Pi on. For shutting the Pi down you'd need an ir receiver along with Lirc to preform the proper shutdown...So you'd have to use two different buttons...
flynpngwn 6 years ago
In general, any power loss to a system has the potential of corrupting data.
I use the Pi to watch my media content, and I'm able to control the Pi with my remote control since it can receive commands from the TV through HDMI. I always do a proper shutdown. With this device I can turn the Pi back on without having to physically re-plug the power.
TheGreyWolfe 6 years ago
I just made my self a game console with a Raspberry Pi 3 and I need this. Not being able to turn it on without plugging it in has been bugging me.
I'm thinking of making a game console as well. I have the Logitech Harmony remote that I use to control this setup. Its nice to be able to press a button and have the Pi turn on. IRP1000 can be found on Amazon.
Absolutelyautomation 6 years ago
Very nice gadget, easy to use without soldering or screw connectors!
Thanks! Its nice to not having to physically re-plug the power to the Pi for it to turn on. I can just use a remote =)
Swansong 6 years ago
Thats a neat setup :)
Thank you!
