Raspberry Pi Tutorial: How to Use the DHT-22
Intro: Raspberry Pi Tutorial: How to Use the DHT-22
The DHT-22 (also named as AM2302) is a digital-output relative humidity and temperature sensor. It uses a capacitive humidity sensor and a thermistor to measure the surrounding air, and spits out a digital signal on the data pin. In this tutorial you will learn how to use the DHT-22 sensor with Raspberry Pi.
Tutorial updates and more Raspberry Pi tutorials can be found here:
http://www.ardumotive.com/how-to-use-the-dht-22-en...
Let's get started!
STEP 1: About the DHT-22 Sensor
The DHT22 is a basic, low-cost digital temperature and humidity sensor. It uses a capacitive humidity sensor and a thermistor to measure the surrounding air, and spits out a digital signal on the data pin (no analog input pins needed). Connections are simple, the first pin on the left to 3.3V power, the second pin to your data input pin and the right most pin to ground.
Technical details:
- Power: 3-5V
- Max Current: 2.5mA
- Humidity: 0-100%, 2-5% accuracy
- Temperature: -40 to 80°C, ±0.5°C accuracy
STEP 2: What You Will Need - Hardware
For this tutorial you will need:
STEP 3: The Circuit
The connections are pretty easy, see the image above with breadboard circuit schematic.
STEP 4: Install Adafruit DHT Library
Before python code you need to download and install the DHT library in your Raspberry Pi. Open the terminal window and type:
git clone https://github.com/adafruit/Adafruit_Python_DHT.git
cd Adafruit_Python_DHT sudo apt-get update sudo apt-get install build-essential python-dev sudo python setup.py install
Now you will have to reboot your Pi system to get the Adafruit driver.
STEP 5: Python Code
2 3 4 5 6 7 8 9 10 11
#Libraries
import Adafruit_DHT as dht
from time import sleep
#Set DATA pin
DHT = 4
while True:
#Read Temp and Hum from DHT22
h,t = dht.read_retry(dht.DHT22, DHT)
#Print Temperature and Humidity on Shell window
print('Temp={0:0.1f}*C Humidity={1:0.1f}%'.format(t,h))
sleep(5) #Wait 5 seconds and read again
Download the code from here and open it with Thonny Python IDE or run it from terminal.
STEP 6: Well Done
You have successfully completed one more Raspberry Pi "How to" tutorial and you learned how to use the DHT-22 sensor.
I hope you liked this, let me know in the comments.
Video in Greek language
5 Comments
OldSurferDude 1 year ago
2. Pin 3? is left unconnected. Does it have a purpose?
syoung1999 2 years ago
instructable that's incorrect. I've tried multiple versions of code to
read this sensor yet I can never get a reading off of it. I've tried
two different sensors, both brand new, I've tried with and without the
10k resistor, all the same results. So when I find my error it will be a
glorious day! (-: Thanks for the instructable.
Output:
Traceback (most recent call last):
File "dht22tutorial.py", line 10, in <module>
TypeError: unsupported format string passed to NoneType.__format__
pi@pi-dev4:~/source-code/python $
Thanks,
Scott.
DominicHo 3 years ago
Thans for the post.
fiftyohms 3 years ago
from . import Beaglebone_Black_Driver as driver
ImportError: cannot import name 'Beaglebone_Black_Driver' from 'Adafruit_DHT' (/usr/local/lib/python3.7/dist-packages/Adafruit_DHT/__init__.py)
Used your code above exactly.
Above code works on RPi 3b but not on new build of Rpi 4 "BUSTER"
I've attempted 2 rebuilds from scratch and end up in the same place.
I have tried to edit the platform_detect.py file but I dont have write credentials to edit the file. I dont know how to cure that either.
(In "/usr/local/lib/python3.7/dist-packages/Adafruit_DHT/platform_detect.py", you can add the followings at line #112 in the elif ladder, so it should workaround the issue.
Thanks,
Jeff
bobs409 3 years ago
