Introduction: Raspberry Pi Universal Remote
In this tutorial I hope to convince you that this is the ultimate universal remote built using a raspberry pi.
LIRC is the perfect for this job. It simplifies many of the more difficult tasks that we need to accomplish.
Step 1: Parts
1 x Raspberry Pi (https://www.sparkfun.com/products/11546)
1 x IR Emmitter (http://www.amazon.com/gp/product/B005BJFDL6/ref=oh...
1 x Audio Breakout Board (https://www.sparkfun.com/products/11570
1 x IR sensor (https://www.sparkfun.com/products/10266)
1 x 2N3906 (https://www.sparkfun.com/products/522)
1 x Female Headers (https://www.sparkfun.com/products/115)
1 x Make Headers (https://www.sparkfun.com/products/116)
1 x Perf Board
Step 2: Setting Up the Software
(Most of this step is from: http://alexba.in/blog/2013/01/06/setting-up-lirc-on-the-raspberrypi/ )
For the sake of this tutorial i'm assuming this is on a clean Raspbian image.
Install LAMP
Install LIRC
Set up the GPIO pins (remember this for later if you want to use other pins)
Add these 2 lines to the bottom of the file
(CONTROL + C will save and exit)
Configure the hardware file.
Erase the contents and paste this file
# /etc/lirc/hardware.conf
# Arguments which will be used when launching lircd
LIRCD_ARGS="--uinput"
# Don't start lircmd even if there seems to be a good config file
# START_LIRCMD=false
# Don't start irexec, even if a good config file seems to exist.
# START_IREXEC=false
# Try to load appropriate kernel modules
LOAD_MODULES=true
# Run "lircd --driver=help" for a list of supported drivers.
DRIVER="default"
# usually /dev/lirc0 is the correct setting for systems using udev
DEVICE="/dev/lirc0"
MODULES="lirc_rpi"
# Default configuration files for your hardware if any
LIRCD_CONF=""
LIRCMD_CONF=""
Reboot the Pi
Step 3: Making LIRC Files
Run the command and press remote buttons at the sensor and you should get some feedback
(CONTROL + C to stop)
Next we run the fallowing command wile in the pi directory to record the remote commands
Fallow the instructions provided
When it asks for key names you must use the predefined names. To get the names I like to open a new window and run the command.
Once you have finished recording, open out.conf
copy from "begin remote" all the way to "end remote" and open /etc/lirc/lircd.conf
Erase the content and paste the code and save.
Assign a name to the remote by replacing the line in the .conf that has a file path after NAME:
Repeat this for all the remotes you want to use
Reboot the Pi
Step 4: Building the Board
The idea here is to build the circuit form the schematic above (the nice one) and replace the LEDs with an IR emitter instead. As you can see in the circuit above (the bad one) the tip of the headphone board is +5v and one of the rings must be connected to the transistor. The Pi does not go fast enough to run the LED itself It must have the transistor to work.
I started by soldering 2 female headers side by side on a perf board.
Then I added the circuit and trimmed the excess perf board off.
Step 5: Now What?
execute remote command to devices with lines like
(device being the name you assigned to it)
Options.
Having a raspberry pi so close to you entertainment center with the ability to turn itself on is a great place to start.
I have set up a MySQL DB and written a PHP file to execute these. Then made a simple HTML page to call these PHP files.
You could write a batch file run a sequence of commands.
I plan to write an App on my phone that will control everything.
The possibilities are endless
As requested here are my html and php files. The SQL is a simple table with 3 fields.
The second field is the command I give the PHP file.
The third is the key that is executed (KEY_POWER).
If you enjoyed this tutorial please vote for it!
Raspberry Pi Contest
123D Circuits Contest
1 Person Made This Project!
- KalaiyarasanE made it!
37 Comments
5 years ago
Sir could you provide a screen shot of the database and the table which is used by the php please ? i just want to see the way the commands are saved there, this is the only part am missing so far to complete the project, please help you could send it to me by mail or here itself please ?!
thank you :)
Reply 3 years ago
Hello,
Do you got an answer to your request ?
I need exactly what you wrote
Reply 3 years ago
Hello,
Did you got any answer to share please?
I need exatly what you wrote
Thank you
3 years ago
I've had a similar thing working for about a year now. running on a zero being my TV.i use Tasker with an ssh plugin to send the command through ssh. it falls about half the time for no apparent reason.
you say that you have a web page for yours. I've been trying to get shell scripts to run using mqtt. but I cannot get it working. anyone have a working remotely controlled way of doing this? mqtt is small and fast, wish I could get it working. but an httpget could be nice too. any help figuring this out would be great.
4 years ago
thanks for above text.i want to know how can we use above thing in a c program that is how can i use irsend command in my c program
4 years ago
i would like to register another control, include that i alredy have, but i'm can't do it... could you please help me?!
5 years ago
hello sir :)
can you provide me with a screen shot of youre DB or can you provide me with a .sql file, everything works fine and i already have a website hosted on my pi and wanted to add a page to control my TV over the web :) please help sir
thank you
5 years ago
Hi, Been having a problem for days getting LIRC installed and running.
apt-get install lirc everything seems fine
Modified the hardware.conf and /etc/modules as per you instructions
mode2 -d /dev/lirc0 this reports an error
mode2 -d /dev/lirc0
mode2: could not get file information for /dev/lirc0
mode2: default_init(): No such file or directory
root@raspberrypi:/etc/lirc#
Also
root@raspberrypi:/etc/lirc# irrecord -d /dev/lirc0 ~/out.con
irrecord - application for recording IR-codes for usage with lirc
Copyright (C) 1998,1999 Christoph Bartelmus(lirc@bartelmus.de)
irrecord: could not get file information for /dev/lirc0
irrecord: default_init(): No such file or directory
irrecord: could not init hardware (lircd running ? --> close it, check permissions)
FYI
root@raspberrypi:/etc/lirc# /etc/init.d/lirc start
[ ok ] No valid /etc/lirc/lircd.conf has been found..
[ ok ] Remote control support has been disabled..
[ ok ] Reconfigure LIRC or manually replace /etc/lirc/lircd.conf to enable..
Running jessie with latested updates banging my head
please help
Reply 5 years ago
Maybe you have another number, not /dev/lirc0, but something else?
What do you have in /dev/?
In my case, I had to manually create a symlink to /dev/lirc0, otherwise /dev/lirc was not present in the system:
sudo ln -s /dev/lirc0 /dev/lirc
5 years ago on Introduction
Note that you've linked to a PNP transistor part at Sparkfun but your circuit diagram shows an NPN.
Reply 5 years ago
Does anyone know what is correct transistor for this - PNP or NPN?
Reply 5 years ago
From the way the LEDs are wired, should be NPN.
Hi,
Thank you for the nice writeup. I having problem to send IRSEND via the web interface. Can you help me to create a 6 button remote?
I have followed your Lirc installation and manage to get it working via the command line. IRSEND -#5 send_once sony key_up ; is good.
Just want to get my html and php to work. Thank you.
I have had a setup like this up and running for over a year. I used LIRC and Webiopi to develop a web based home automation system that controls my home theater system. Initially I had issues with wifi dropping every couple of days and then had issues with SD card corruption. I think both of these were cause by not having a big enough power supply. I recently created a board and kit that can drive seven IR LEDs and has a receiver to make it really easy to build. Even after the electronics are assembled it can take some time to get all of the codes programmed. You can buy the kit it here. http://www.slimbots.com
I followed the Complete Process But as i stop lirc :
pi@raspberrypi ~ $ sudo /etc/init.d/lirc start
This is coming . i changed the Hardware.conf file and added those two lines in modules as well. .
pi@raspberrypi ~ $ sudo /etc/init.d/lirc stop
pi@raspberrypi ~ $ mode2 -d /dev/lirc0
When i run this command it is showing this. Can u please Help me. lirc/devo is not created. . . What to do with this ??? Please help me urgent.
6 years ago on Introduction
Parts list links are no longer working... how about digikey? (and perhaps part numbers on build list just in case links break again)
Thanks
Reply 6 years ago on Introduction
remove the bracket " ) " from the end of the link...
Why can't i create a lircd.conf for a remote?
RC-6 remote controle found.
Found possible header: 226 762
Header is not being repeated.
No repeat code found.
Signals are biphase encoded.
Signal length is 23
Checking for toggle bit kask.
Please press blah blah.......
Press RETURN to continue.
And then right after pressing a button it tells me:
No toggle bit mask found.
But I know for sure that RC6 has a toggle bit!
And the program stops and no file is made. The remote is for a arcadyan model HMB2260.
This box controles my digital tv so with out it my remote controle setup is useless
Please can some one help, google doesn't seem to be much of a help!
6 years ago on Step 4
how did you configure the emitter, i wire it as you show but i cant make it work. it just blink but doesnt turn on of off anything
6 years ago on Step 3
I tried to make this /etc/lirc/lircd.conf file by downloading and concatenating all remote control files that you can find (also on the lirc website). But I never got it to work. Maybe you post your /etc/lirc/lircd.conf file and we can see where the problem is.
THANKS
-M
