Introduction: Raspberry Pi: Wall Mounted Calendar and Notification Center
Before the “digital age” many families used wall calendars to show a monthly view of upcoming events. This modern version of the wall mounted calendar includes the same basic functions:
- A monthly agenda
- Sync of family members activities
- Easy browse between months
Beyond those basic functions this gadget will also handle:
- A whether forecast
- Upcoming events in the surrounding area
- Live information about the public transport
- And even more...
What you need:
- Raspberry Pi 2
- USB Wifi Dongle. (Like Edimax 150Mbps Wireless nano )
- LCD laptop screen (take one from a broken laptop https://www.instructables.com/id/Old-laptop-screen...
- Controller card for the laptop screen (search Ebay for LCD Controller Driver Board and the serial number of your laptop screen)
- Some Push Button Switches (Like http://www.ebay.com/itm/16mm-Start-Horn-Button-Mom... )
- Webserver running a custom made homepage
- Piece of wood. Height should be more than 30mm, so the electronics can fit inside. The width and height depends on the size of your laptop screen.
- Sheet of cork. (Like this http://www.pandurohobby.se/Katalog/50-Skapa-Dekor...
- Short HDMI cable
- Powersuply for controller board and Raspberry Pi.
- Foamcore
- Glue.
- Mounting screws .
(Inspired by the instructable by Piney https://www.instructables.com/id/Raspberry-Pi-Wall-...)
Step 1: The Hardware
This is the hardware setup.
- Find a LCD laptop screen . Order a controller board on Ebay. Search for LCD Controller Driver Board and the serial number of your laptop screen.
Read more: https://www.instructables.com/id/Old-laptop-screen-.. - Craft a piece of wood. Height should be more than 30mm, so the electronics can fit inside. The width and height depends on the size of your laptop screen, have a margin for an extra 10 mm on all sides. Carve out and make room for the electronics on the back. Drill holes for the buttons and wires.
- Fasten the laptop screen. I used the orginal mounting frame from the laptop.
- Cut out foamcore with equal thickness as the screen. and glue it on the wooden slab.
- Cover all sides with cork. Cut with a “snap-off blade knife” and glue with “glue spray”.
- Mount the Push Buttons. Use a large drill, and drill carefully by hand.
- Connect the electronics. Connect three of the Push Buttons to GPIO-pins 19/20/21 and to ground. https://ms-iot.github.io/content/images/PinMappin... Find out the pin for On/Off button for the controller board, and connect it with the fourth Push Button. (You will find it by trying to connect ground to each pin, suddenly the LCD will light up). Finaly, connect the HDMI cable between Raspberry and controller board, and connect the screen to the controller board.
Step 2: The Software
The setup is somehow turning the Raspberry Pi into a kiosk. The OS will auto start a website in full screen mode,
and the Push Buttons is used to control the information at the website. The setup is:
- Install Raspbain on Raspberry Pi
(https://www.raspberrypi.org/documentation/installation/noobs.md) - Sign up for a Google Calender. (https://calendar.google.com). Add your upcomming event. Ask for access to your family members calendar, or create a speceific "family calender" and give the rest of the familiy acess to it. Make your calendar more dynamic by adding external calenders. Facebook events, public holidays, and week number has been practical for me. More inspiration here: http://lifehacker.com/the-coolest-things-you-can-a...
- Set up a webpage and a webserver
- Install a web browser and customize the calendar design
- Set up the push buttons
Continue reading for details about 3-5 .
Step 3: Create a Webpage and Webserver
The webpage is the canvas the Raspberry Pi will display. The canvas can be filled with any information. I will show you how i to embed a google callender. The embeed code is generate by googles own aplication. This youtube shows how to get it to work: https://www.youtube.com/watch?v=2tnYwbs-yDk
Google Calendar have built in keyboard shortcuts. Press N and the next month will appear, press P and the previously month is shown. This will only work when the < iframe > is in focus. I have created a JavaScript that ensure that focus is correct.
An example file of html code is attached (change name from index.html.txt to index.html). For privacy, I have replace some of the code with “*___REPLACED___*”. Instead, use the embeed code generated by google.
Either put the index.html file on your own webhost, or turn your Raspberry Pi into a webserver and host it local. If you already have a webhost continue to the next step. Install a webserver by following this guide: https://www.raspberrypi.org/documentation/remote-a... Now save your modifed index.html to /var/www/html/index.html, like this:
sudo cp index.html /var/www/html/index.html
Step 4: Install a Web Browser and Customize the Calendar Design
There a many web browser out there. But I have only find one that can handle these three requirements; 1) can handle the modern version of google calendar, 2) has a full screen mode, 3) can run a local CSS. The local CSS is used to change the appearances of the google calendar. The redesign can’t be done at the webpage, because the CSS are embedded from another server (the google-server).
Install Iceweasel (Firefox for Linux)
https://www.youtube.com/watch?v=69fwZ8yMnz0
Install this extension for Iceweasel:
https://addons.mozilla.org/en-US/firefox/addon/stylish/
Open the “Stylish” extension tab in Iceweasel and customize the CSS to make the google callander look better. Se attached file i for an example.
Now, lets make Iceweasel to autostart and open your webpage at login. Type this in the Linux terminal:
cd /home/pi//.config/autostart nano cal.desktop
Write the following to the file. Change "localhost" to adress where your canvas-webpage are stored. Save and exit.
[Desktop Entry] Type=Application Name=hemsida Exec=iceweasel localhost StartupNotify=false
Step 5: Set Up the Push Buttons
The Push Buttons is used to browse forward and backwards in the calendar month view. By default this is done by pressing “p” and “n” at a keyboard. Therefore the buttons will emulate those two keyboards commands.
First, create a python script to make the push buttons work: http://razzpisampler.oreilly.com/ch07.html
Download and install python-uinput, a python API to create virtual keyboards: http://tjjr.fi/sw/python-uinput/ Raspbian comes with both Python 2 and Python 3. Make sure you install uinput with the version you are using.
Put the uinput-API and the button script together. The final python scipt is attached.
Auto-start the python script on startup: https://www.instructables.com/id/Raspberry-Pi-Laun... Our launcher.sh will look like bellow. Replace “/home/pi/py_switch” to the path where you have stored the python script.
cd / cd /home/pi/py_switch sudo modprobe uinput sudo python switch.py cd /
That's all!
UPDATE:
The number of possible commands can be extended with some if-else-statements in the python code. I have attached an upgraded switch.py-file in this step. The new is script has the following commands.
- Press button 1 -> Key press “P” -> Browse previously month
- Press button 2 -> Key press “N” -> Browse next month
- Press button 3 -> Key press either "M" or "A" -> alternate between month-view or agenda-view
- Long-press button 3. -> Key press "F5" -> Reload the webpage
- Simultaneous press button 1, 2, 3 -> executes the shell command “sudo reboot” -> Restart of raspberry pi.
25 People Made This Project!
- sobrudolph made it!
- Daniel Frechette made it!
- jmolshove made it!
- scottryan5150 made it!
- 518design made it!
- tangozulu10 made it!
- PeterL190 made it!
See 16 More
203 Comments
Question 4 years ago
I installed a web server on Raspberry PI, but in order to see the Google calendar, I would have to make the calendar "Public"... or am I missing something?
Answer 1 year ago
Hello, did you have to make this public?
Question 3 years ago on Step 3
Why the need for a server? Why not just make and place html file on pi desktop and open in browser, refresh every x minutes.
Answer 1 year ago
Hello, did you manage to do this without a server?
Question 2 years ago
Do you always have to order a controller board? There is not one from the laptop it came with that you could use?
I made it and until I came to the step with python, everything runs good.
When I install and run the python script as described, it seems that the buttons are pressed permenently.
I tested the buttons and they are installed correctly (activating by pressing).
I put all GND on PIN 39 and the others on the GPIO PINs 19,20 and 21. I used the launcher.sh as posted und the location of the launcher.sh and the switch.py is /home/pi/py_switch
Maybe someone could help me to fix that problem.
Answer 3 years ago
Ok..I found the reason, why it seems that the buttons are pressed permanently.
This YT-Video shows, how the buttons must connect with the RPi GPIOs:
It's important to watch!
Inwant to build one of these for my father who is just beginning to develop dementia, this will my first raspberry or arduino project. Can I use a led tv? Looking to have a screen about 32 inches for him? Thanx for any feedback
Answer 3 years ago
It should work with an LED TV, when the TV has an HDMI Input. Then you can plug the RPi into the HDMI port nd everything should work.
If you have "only" a 32" screen, you must order a display controler. How it works you can find many videos on YouTube.
One thing please:
When you install the launcher.sh and the switch.py could you give me a feedback, if the launcher.sh and the switch.py works?
THX
Question 4 years ago on Step 1
Thanks very much for posting this! Quick question: any reason why a normal LCD monitor (desktop-style) wouldn't work instead? Would that keep me from needing to buy a controller board (seeing as it should come with one, and would just need to be pulled out of the case like the screen itself)? What am I missing?
can you create a new event on the calendar and is this to big of a sheet?
https://www.amazon.ca/Plain-Cork-Sheet-Thick-Singl... will this do as a power supply?
https://www.bestbuy.ca/en-ca/product/vonnic-vonnic... how big of a peice of foam core is used, what type of glue do you use and how many mounting screws do i need? by the way, i have my calendar hung up on the side of a cupboard in the kitchen
4 years ago
the link http://lifehacker.com/the-coolest-things-you-can-a... dosn't open, https://cdn.instructables.com/ORIG/F56/WZI1/IIXF7U... and https://cdn.instructables.com/ORIG/F29/HE08/IJRFH6... does not open when downloaded, is there a video on putting it together and can you use a raspberry 3 B+?
Hey guys I just finished my notification center and I found that the webpage sometimes fails to load usually over night. Has anyone else run into this issue?
6 years ago
Hi,
Do any of those that have made this project know if it would run on a Pi Zero?
Cheers
Reply 6 years ago
Having tried very hard to make this work reliably on a Pi B+, I wouldn't advise using a Pi Zero. From personal experience I'd recommend a Pi 2 or 3 for this.
Reply 4 years ago
I have this running on my pi zero w, and it seems to run well. I'm using Firefox ESR instead of Chrome, and serving index.html with Apache.
Also using mfull extension to force full screen on startup.
The CPU usage is high, but since this is it's only job, I'm not concerned about it
I was unable to get the Darksky weather to display, apparently a problem finding a link or file, so I changed to WeatherWidget.io, which works very well, and is also free.
I am about to tackle the button set-up.
6 years ago
?Hello,
Thanks for the scripts, may I suggest to add an extra time.sleep(0.1) at the very beginning of the loop ? otherwise your processor ( top ) will be almost 100% dedicated to run the python script ...
cheers !
Reply 4 years ago
So, you're exactly right about the CPU being over taxed by the python script. In fact, I have one core almost fully dedicated to chrome and one for the python script. I am looking for suggestions on how to fix this. With your time.sleep(0.1) suggestion, where exactly would that be placed in the script? I read your suggestion to put it at the beginning of the loop. Does that mean in the loop or before it? If you can, would you define that a little more? Thank you.
Question 4 years ago on Introduction
Has any one figured out a solution for reducing the CPU usage for the Button Script? I just ran the script on my RPi 3 and it tops out and hold near 90%. I would like to use the script just to refresh the screen.
4 years ago
Hey guys, so i just found this project and am looking to build it.
i was reading through and decided to check the pinout stuff.
according to :http://www.raspberry-pi-geek.com/howto/GPIO-Pinout... the pinout for 19,20,21 would mean that GPIO 10, Ground & GPIO 09 are being used, is this correct.
Hooking up the buttons is the one thing im slightly confused on.
Looks like in the picture 1 button is also connected to another with one of the wires. Im am not familiar with these types of buttons so that may also be part of the confusion.
Is someone able to put together a wiring diagram for the button and pinout please.
Thankyou.
