Raspberry Pi Power Cable Adapter.
Intro: Raspberry Pi Power Cable Adapter.
Notice: This instructable requires knowledge of electricity and the ability to solder. We are not responsible for any and or all issues. Do this at your own risk to any life and or equipment. Get a professional to help even if you are the least bit unsure.Do not solderor touch anthing while connect5ed to power supply.
STEP 1: What Is Needed:
Micro (not mini) usb cable.
Female power plug that will hold the male end of the power supply
We will use the packaging for the female power plug as a temporary case.
Tools:
Wire strippers/cutters
Soldering iron
Solder
Tape.
STEP 2: Dissecting.
Once you have cut the cable, strip back the main outer covering.
Strip the red and the black wire so they can be soldered to the barrel connector.
If you do not have the standard color coding, you will have to test the cable manually. Be carefully not to touch any bare wires while doing this, as you could be electrocuted. If you are unsure, get a professional to help.
STEP 3: Solder It.
Solder the +5 wire (maybe red) to the tab that goes to the inner tube.
Solder the ground wire (maybe black) to the tab for the outer tube.
Let cool.
STEP 4: Wrap It Up.
STEP 5: Bonus: Gpio Adapter.
Note: Looks better than using a disk drive cable.
STEP 6: Another Suggested Implementation.
STEP 7: Use an Old AT (NOT Atx) Power Supply.
Do this at your own risk. We will not be responcible for any or all issues. Chances of electrocution causing death can occur. Get a professional to help before you start this project if you are even the least bit unsure.Be sure to cover any exposed live lines to insure there is no electrocution risk.
Wanted to make a Raspberry Pi where I could have several units in one case. Putting several power supplies in one box seemed like a mess. Instead I decided to use an old "AT" (not atx) power supply. I did not want to cut up the cable from the power supply. I looked for a dead motherboard in the junk box. There was onthe picrure attached:e! Now, had to get out the old heat fun (used for paint removal. Most "AT" motherboards are attached to the pc like
But if you have a dead motherboard it will not need the Power supply header anymore. So the mother board looked like the picrure attached:
Now we want to add heat to the back side of the motherboard to release the header. Be careful as it is HOT. Solder could come flying and burn you. Wear protective clothing. Then once the header is free and cooled, it should look like
Ahh, free parts!! So now I can use the header with the Raspberrty Pi once I have soldered some wires to the header. PC Power supply must be turned off and disconnected from wall power while soldering. I.e solder the header disconnected from anything. Hint: Be sure to also use a glue gun to seal the solder connections so nothing can get shorted out.
You will need a pinout listing for that particular power supply you want to use. (Varying power supplies are not all the same when it comes to the pinouts!!)
This power supply only uses two of the three connectors. But what we need is a +5v (usually red) and a ground (usually black) to power the Raspberry Pi. So we could eventually power up to four units. The disk drive cables could aso be used, but we let them be for drives we could attach to the Raspberry Pi.
STEP 8: Potential Power Supply Idea.
Warning: Try this at your own risk. I will not be responsible for any or all issues.
Came up with a possible idea for a power supply using a 12v battery so that the Rpi is semi-portable. I also planned on using an NTE931 not the 7805T as the voltage regulator. Still need to add a switch and a fuse to the circuit, so you may see an update eventually. I am not an electrical engineer or anything remotely resembling one. This is what I came up with that might work, but it is definitely untested. Get a professional to help you with this. As I said try at your own risk. If someone has a better circuit please let me know.
STEP 9: Yet Another Ps.
While going through my old files, I found this picture, but never tried it though
5 Comments
Gelfling6 10 years ago
a simple SPST switch, simple On/Off..
2 Bananajack binding posts (for drawing +5v for projects)
a $1.00 store USB cable that fits the power socket on the Pi, cut, red & black wires longer, green & white staggered cut so they wouldn't short.
barrel jack & plug that match to the USB hub power supply & hub.
7-port USB hub w/a 3.0A minimum external +5V supply.
Idea being, putting the switch between the jack & the wires to the +5V banana Jack, the center cable of the USB hub plug, and the red USB cable wires. GND to all common (the black USB wire, the black banana jack, the shield of the USB hub plug, and the shield of the jack.) this way, I had all 7 ports available on the USB hub, and I could turn the whole system on & off from the switch box. Now, the fun.. Actually finding time to sit down, and tinker with the Pi.
DJAdamDaniel 11 years ago
In fact this is partly (along with cost) why the Pi doesn't come with one out the box - because many people (especially the 'geek' types that will buy this) already have 5V USB.
Computothought 11 years ago
amandaghassaei 11 years ago
