Raspberry Pi Tracer Interface
Intro: Raspberry Pi Tracer Interface
Everything started with the fact that the MT-5 display wasn't what I really needed. I was in the need of checking the charging from the device using the battery: my trusty Raspberry pi (1 B at the time). I managed to stumble over this instructable (https://www.instructables.com/id/Use-Arduino-to-Com... and git project (https://github.com/xxv/tracer/). So the code and research isn't mine.
But this was made for the arduino, (why use a USB and arduino when you have the capability on the raspberry pi?)
So i bought the EP solar MPPT solar controller from eBay + MT-5 display. That got me thinking that it should be possible to collect and store the data for later use. Said and done I started to search after the protocol specs and found what I needed here [Protocol] and as a nice bonus there where some code for arduino and python.
So with this information and code this was quite a easy task.
STEP 1: (Optional) Try on a Arduino.
You might consider this step to make sure you have hooked up everything the right way. Since the arduino is a little bit more forgivning then the raspberry pi (only 3.3v and will die if you hook it up wrong).
On my RJ45 cable it was:
arduino pin 10 to Full blue
arduino pin 11 to green/white
Arduino pin GND to orange
Double and triple check this before you hook it up, there are some 12v pins!
Arduino code: Arduino code
Does it work?
Great! Go on to the next step.
Else check your connections
STEP 2: Step 1: the Hardware
You will need:
1. raspberry pi with appropriate cables and case.
1,5 A SD card 8 gb microSD for the newer ones
2. A RJ45 cable that you don't like (but is working)
3. Connectors to hook the 2 together. I lab with ( http://www.ebay.com/itm/40PCS-Dupont-wire-jumper-c... )
4. A Tracer MPPT controller (or equiv.)
5. 12 v battery
6. Solar panels
STEP 3: Making the Cable
Follow the pictures.
CHECK WITH MULTIMETER!
Black= GND
STEP 4: Step 2: the OS
STEP 5: Step 3: the Software
When first booting Expand filesystem
if you allready have a active Raspberry Pi
start "sudo raspi-config"
Choose 8
Then A8
And No ("Nej" is no in swedish)
Finish
Do a
git clone https://github.com/xxv/tracer.git
cd tracer/python/
python query_demo.py
STEP 6: Step 4: Troubleshooting
Nothing happens
Most common reasons are:
switched TX/RX check connections.
to be continued (please use comments)
STEP 7: Modifications
I made a small testscript that you can put in the chrontab
17 Comments
lfondel 1 year ago
MarkG394 5 years ago
NikolayN16 5 years ago
It looks like EPEVER changed the pinouts of the RJ45 plug, I just receive it and by the instruction they look like this :
The RJ45 interface pin define is shown below:
1 Power supply output +5V
2 Power supply output +5V
3 RS-485-B
4 RS-485-B
5 RS-485-A
6 RS-485-A
7 Ground
8 Ground
achituv 7 years ago
I just released a new library for Arduino which supports both querying as well as controlling the Tracer MPPT, available here: https://github.com/compugician/arduino-tracermppt
abbbbuuuu1 6 years ago
hi will this work of rasburry?
DustixM 6 years ago
Does someone know how I can let the Raspberry PI execute this command at a certain time interval and save the data on an SD-Card?
MarkA229 7 years ago
thanks for a well detailed tutorial. Am trying the same setup and when ever i run the query_demo.py i get this error.
Traceback (most recent call last):
File "query_demoMOD.py", line 43, in <module>
result = t_ser.receive_result()
File "/home/pi/tracer/python/tracer/__init__.py", line 128, in receive_result
if read_idx < len(self.sync_header) and b[0] != self.sync_header[read_idx]:
IndexError: bytearray index out of range
How do i resolve this issue please.
DokMartin 7 years ago
getting the same thing on mine
MarkD127 6 years ago
Hey Dok, did you get this working ? I'm getting :
File "/home/pi/tracer/python//tracer/__init__.py", line 128, in receive_result
raise IOError("Error receiving result: invalid sync header")
IOError: Error receiving result: invalid sync header
DokMartin 6 years ago
I'm sad to say I corrected this issue by changing my Tx and Rx wires, which I had backwards. Good luck!
technomupet67 7 years ago
Hi, I am trying to connect directly to Raspberry Pi using USB Serial converter. I am getting the same error as the person above. I am assuming it is a ttyUSB setup issue. Does anybody know how to solve? Thanks
madale2010 7 years ago
Sorry jensah I didn't see your link to the protocol page which goes into great detail the wiring diagram. I do beleive I have the correct wiring and setup on the hardware side. After research I think there has been updates to the rasberry OS and disabling of serial ports so I will try to fix this first. As of now I'm just trying to see any transmittion bytes from the tracer to the raspberry. Currently I can't see any logs of such entry, therefore the script does not do anything which is to be expected :)
ColinH4 7 years ago
I'm curious what are people using this for, are you able to get it into something such as domoticz or pvoutput?
danrulz98 7 years ago
Hey, any chance of modifying the xively output for PVOutput.org? They just want CSV seperated data fields.
RichardP97 8 years ago
Did you have any issues with ttl to GPIO (+3.3v) voltage difference? There care differing reports on the voltage from TX to ground (5v vs 3.3v). There are reports of people blowing up their Pis - for example https://www.raspberrypi.org/forums/viewtopic.php?f=63&t=54098
amberrayh 8 years ago
This is very helpful. Thank you for sharing! I hope we see more from you in the future.
