Ratatouille (Confit Byaldi) From the Ratatouille Movie
4,929
92
18
Introduction: Ratatouille (Confit Byaldi) From the Ratatouille Movie
Ratatouille is one of the most classic French dishes. This one-pot meal was invented by the French peasants in the Provencal region of Nice, in the 18th century as a quick and affordable meal to help deplete the abundance of summer vegetables that would otherwise have gone bad.
In 2007, Ratatouille became well known to the world with the Disney Pixar's animated movie about a rat with very well-developed senses of taste and smell. At the end of the movie, the protagonist prepares a more contemporary version of ratatouille: the Confit Byaldi. Instead of mixing all the chopped-up vegetables in a pot, this version presents all the ingredients in a nice and organized fashion, while also replacing the peppers with mushrooms.
In this Instructable, we are going to make a Confit Byaldi using the ingredients from a classic Ratatouille.
Let's get cooking!
3 tbsp of olive oil
4 tomatoes
3 lobes of garlic
1 or 2 eggplants (depending on the size)
1 or 2 zucchinis (depending on the size)
1 paprika
1 onion
1 cup of tomato sauce
Some basil leaves (optional)
Salt and pepper
Note: try to find tomatoes, eggplants, and zucchinis that have all about the same diameter.
Step 1: Chop
Chop the onion and garlic into small pieces. Also now is a good time to turn on the oven and preheat it to 375˚F (190˚C).
Step 2: Make the Tomato Sauce
In a pot, heat up the olive oil. Add the chopped-up onion and garlic and stir for around 7 minutes until the onion has turned golden.
Add the tomato sauce, the basil, and salt and pepper. Bring to a boil while stirring constantly, then remove from heat and let the sauce cool down.
Step 3: Slice
Slice the zucchini, the eggplant, the paprika, and the tomatoes into thin slices - the paprika can be cut in two before slicing.
Step 4: Arrange
Pour the tomato sauce in a 12-inch (30 cm) ceramic baking tray or a cast-iron oven dish. Spread it evenly.
Now, place the sliced-up vegetables on the tray, forming concentric circles, while alternating the different ingredients. For example: Zucchhini / tomato / eggplant / paprika / Zucchini / tomato /.... The slices should be submerged halfway into the tomato sauce.
Start from the outer edge and make your way towards the center. The last slices can be arranged in a line to cover up the empty spot in the middle.
Grind some salt and pepper on top.
Step 5: Bake
Wrap the tray in aluminum foil and place it in the oven for 50 minutes. Then, remove the foil and place it back in the oven for an additional 15 minutes.
Step 6: Done!
Remove the tray from the oven and serve right away. Ratatouille is best when still hot!
Enjoy!
Fruits and Veggies Speed Challenge
First Prize in the
Be the First to Share
    • First Time Author Contest
    • Backyard Contest
      Backyard Contest
    • Build a Tool Contest
    18 Comments
    Larry_French
    Larry_French
    6 days ago
    I'm impatient to try this. It looks delicious !
    Handy_Bear
    Handy_Bear
    Reply 3 days ago
    Thanks!
    FloP
    FloP
    8 days ago on Introduction
    This looks nice but as a French person living in the South I must tell that it’s not Ratatouille, it’s a Tian! It was misnamed in the movie.
    TheHandCraftHob
    TheHandCraftHob
    19 days ago
    Looks delicious! Will definitely try.
    JMorton3
    JMorton3
    25 days ago
    Just before the list of ingredients, you stated " ... this version presents all the ingredients in a nice and organized fashion, while also replacing the peppers with mushrooms.". Did you replace the pepper with the mushrooms?
    Handy_Bear
    Handy_Bear
    Best Answer 24 days ago
    No, I didn't, I kept the pepper. But the Confit Byaldi invented by chef Michel Guérard does. That's what I wrote further down: "In this Instructable, we are going to make a Confit Byaldi using the ingredients from a classic Ratatouille" - we keep the appearance of the Confit Byaldi, but use the original ingredients that go into a peasant style Ratatouille.
    Lazarus0
    Lazarus0
    26 days ago
    Looks and sounds delicious. Hard to find actual bell peppers locally, but soon I'll be growing them (and anything else I can get seeds for). I think the local bell-type pepper is called Atsal.
    They are also smaller, but the local eggplants are thin and tubular so the diameter of the slices will end up being smaller, too, but still uniform sized.
    I'm also thinking that a few nice variations would be to add some sliced Italian Salsiccia, or, sliced pepperoni, or even sliced salami. Hmm, a French version of an Italian dish...
    jackorth44
    jackorth44
    27 days ago
    Hi looks very nice but where did you put the red pepper?
    Handy_Bear
    Handy_Bear
    Best Answer 27 days ago
    Hi! Thank you! It went between the slices of the other vegetables.
    jackorth44
    jackorth44
    Answer 27 days ago
    Thank you, maybe this will impress the grandkids. Ratatouille!
    arex
    arex
    27 days ago
    I've made this from a similar recipe a few years ago, and it was amazing. I think there were only slight variations between that recipe and yours, so I'm sure yours is going to be great when I make it this weekend.
    bag831
    bag831
    27 days ago on Step 1
    In the ingredients you state tomato sauce but in the instructions you mention adding the tomato paste. Which is it as they are 2 different things
    Handy_Bear
    Handy_Bear
    Oops, yes, it is tomato sauce. Thank you for pointing that out! I will change it right away. :)
    ShamWerks
    ShamWerks
    27 days ago
    as a French person living in the Provencal region of Nice (though not a peasant), I was actually looking for this very recipe! Thank you, will definitely give it a go!
    Handy_Bear
    Handy_Bear
    Reply 27 days ago
    Merci beaucoup pour votre gentil commentaire! :)
    MerrillA1
    MerrillA1
    27 days ago
    I will definitely make this, one the veggies.
    Ronna Farley
    Ronna Farley
    4 weeks ago
    Great way to use homegrown veggies!!!
    Handy_Bear
    Handy_Bear
    Reply 4 weeks ago
    Thanks!
