Re-Tread Your Slippery Pedals
Intro: Re-Tread Your Slippery Pedals
Cycling in the rainy NW ,pedals without clips require Grip . Heres a quick cheap (free) way
to give new traction to your old slick and slippery pedals before you slide off and crunch
your shin or 'you-know-what' =( . It was just about to happen to me .
STEP 1: Dremel Will Travel
This could also be done with a hacksaw blade but a dremel is what I used .
It took all of 5 minutes . This is my 1st ible so feel free to lay on the critiques .
STEP 2: Things U Need (tools)
gather your stuff :
-SAFETY GLASSES (&or face shield)
-SAFETY GLOVES
-pedal wrench (usually 15mm)
-pedals
-dremel & cutoff wheel or hacksaw blade
-SAFETY GLOVES
-pedals
STEP 3: GRIND SOME GRIP
I alternate the direction that i cut the grooves hoping for better foot traction .
Every other spike cut alternates 90 degrees from the one next to it .
I also cut a few lines into the flat surfaces of the pedal for good measure
STEP 4: Re-install Pedals
clean off the metal shavings .
put em back on your cranks .
Go test with your usual bike shoes .
.. Tested . The pedals have at least 75% more grip.
I recommend giving it a try with some worn but working
pedals .
I'm gonna try and add grip to some worn plastic Odyssey 'Twisted'
pedals next . Stay tuned please.
pedals .
14 Comments
Databanks 7 years ago
I'm wondering if you could use some silicon to add friction instead. Opinions? Or maybe both
dkfa 11 years ago
dkfa 11 years ago
mbecks 10 years ago
BtheBike 11 years ago
these resurfaced pedals are Nowhere near as aggressive . Instead the gripping property is recessed unlike beartrap type pedals
dkfa 11 years ago
The pedals that caused that picture though were my welgo ones.
Yard Sale Dale 12 years ago
I have some pedals about like that. I have been collecting little set screws and got a tap in the same size, hoping to just drill for traction pins and threadlock them in place.
The ones you show with screws for the plastic pedals may work, but you should saw-off the points or surely you will spike your shoes and maybe cut your leg really badly. Good luck.
BtheBike 12 years ago
The plastic ones would the head screw head as the foot contact surface , not the screw point . You're right , that would asked for shredded shins =/
They actually make pedals with screw heads type surface .
Love to see your ible with your pedal idea . Sounds pro =)
Best bet is to find a bulk fastener dealer like Fastenal or mom-n-pop hardware store. You will need 8-16 set screws per pedal. Cheap nail polish works for threadlock on many non-critical things. Taps are about $2-5 each for small sizes that grub screws come in.
I've made diy powerstraps like these https://www.instructables.com/id/Pedal-Belts-for-cycling-efficiancy/?ALLSTEPS didn't prefer them compared to flat pedals really .
I prefer removing the dust cap with small driver rather than making a hole. I used mid-viscosity grease gun ,on spindle ,threads, bearings.. . Like new =)
vader9900 12 years ago
Can't beat the original prototype
