Real Lava Lamp
Intro: Real Lava Lamp
This instrutable is on a real lava lamp. I've seen Lava lamps on you tube and google but they are never real lava lamps the ones that are powered by a light or candle. Hope you enjoy this instrucable
WARNING THSI IS HIGHLY FLAMMABLE
MAKE THIS AT YOUR OWN RISK
STEP 1: Materials
Voss drink bottle 800ml
Olive oil or other oil
Water
Candle wax or old candle
Methylated spirits
Old food can
New candles
Water
Methylated spirits
Old food can
New candles
STEP 2: Coating the Spring in Wax
Coating the spring in wax is so that the spring will stick to the rest of the wax when it's all done.
So you start off with getting the spring out of the pen then grab your wax and place it into a card board cup and place that in the microwave for 3:00 minutes then take it out and pour a couple of mls of methylated spritis in with the wax
Then place the spring in the mixture and place it in the fridge to cool for a couple of minutes
Once it has cooled pull it out of the wax before it has fully solidified and then just place the spring back in the fridge
STEP 3: Making the Mixture
Pour 250ml of water in the glass bottle
The pour 700ml of methylated spirits Into the mix
Pour 25 ml of olive oil and then add two hand fulls of wax into the mix I used a funnel that I made out of a soda bottle
STEP 4: Making the Stand
Drill 8mm holes into the steel can
Grab a candle and place it in the can you may have to prop it up to get it high enough light the candle and place the lid on the voss drink bottle then place it on the can with the candle lit then wait three hours for the lamp to heat up then just sit back and watch the show
REMBER TI VOTE FOR ME PLEASE IN LIGHT CONTEST
6 Comments
septimus0804 3 years ago
eugopnosaj 7 years ago
JakeNbritneyRoss 5 years ago
BenjaminC125 6 years ago
If you used an 800 ml bottle, how did you fit over 975 ml of fluid into the bottle (250 ml water plus 700 ml of methylated alcohol plus 25 ml olive oil plus added wax)? Am I missing something?
Batmantwo 6 years ago
Batmantwo 7 years ago
the spring is there two heat up the wax and oil from the inside and the spring is there to make it quicker for the candle to heat up
basically it is just there to speed up the process
