Introduction: Really Loud DIY IPod Touch Dock With Speakers
My home made ipod dock from an old 2.1 speakers system.
First off all, i want to apologize for my bad english, but i hope you will understand me.
requirements:
Ipod
ipod dock adapter (it came in package with ipod)
ipod audio-video cable
speakers (winth integrated amp)
a few tools, little knowlage about electronic
Step 1: Destroy
take a part speakers system
Step 2: Draw and Cut
Drill holes for
Dock adapter
Speakers
power, volume, bass button
Step 3: Box
just a few photos so you can see how box looks like
Step 4: Dock Adapter and Audio/Video Cable Edit
Now, you gonna need to remove thise hooks that ipod holds on for video cable.
IF YOU DON'T REMOVE THIS, YOU WILL NOT BE ABLE TO DISCONECT IPOD FROM CABLE WHEN EVERYTHIG IS ASSEMBLED.
Step 5: Connecting Everything Together
Step 6: Final Touches
Step 7: Finished!!!
Step 8: COMMING SOON :)
requirements:
Ipod
21 Comments
7 years ago on Step 5
good idea, and cool project. id like to do this sometime with a harmon kardon 2.1 setup (great sound.)
8 years ago on Introduction
Hello, this looks great. i would like to use the same ipod connection you created. i have 2 jbl floor speakers (10" woofers , 4.5' midranges , 1" tweets, 175 watts, 8 ohms.) would my ipod be compatable with these speakers? i would like to keep the speakers intacted, basically add the ipod connection.
Rs
8 years ago on Step 7
Nice!
Hi, my boss just gave me a brand new set of speakers for free (YAY) but I only have about a $20 budget to make/buy an amp. Obviously I can't get an amp with enough power for $20 in this day and age. The speakers have a combined output of 200 watts. Could I (theoretically) build all this and make it 200 watts while staying within my budget?? I have MOST of the wires, circuitry, tools etc. because my father has 5 old computers, builds robots, and is generally very handy (mechanical engineer). Any help would be VERY much appreciated, as I am currently running on a measly 27 watts :'(
I have used NXT flat panel speakers without an amp for listening to music at night in bed. i tried using head phones not enough volume there even seting the headhones on your head . then you can toss n turn without having to constantly beaware of the head phones. I then tried the behind the neck style head phones again whowants be on their back all night sleeping in one position. i had battery operated amp plus nxt flat panel speaker it had pretty good sound amplification but a drain on batteries was constant cant expect them to last if left on while you fell asleep. now a solar battery charger and battery operated amp plus nxt flat panel speaker would be ideal dock. i noticed at secondhand stores they have small amps like trhis often for few dollars.
9 years ago on Introduction
I dont know if this question is silly because i have a PC Desktop speaker which needs a input of 220v so can i power it by 9v. will it work.
no
dog digger, with all respect, but you're maybe not totally right. I don't think the circuit of the amplifier works on 220 volts. If you screw open the speaker box with the controls in it, you will maybe see a thing where the 220 volts wall socket wire goes in. You have to read what's on that thing. Maybe it tells you it outputs 9 volts of DC power, which means you can actually replace the wall socket wire and that transformator with a 9 volt battery! I don't know if this works with every pair of speakers, but my speakers do have such a thing ;)
Even then, most cheap speaker systems just run into a transformer and then the the circuit without any rectification. It might work. Just look at the output of the transformer and sometimes, depending on the system, it might work on a DC supply. You need to look inside the unit and check. No system that I've seen directly runs on 220v. I've seen 35v rails as the most common. The real answer is, who knows?
Hey r they Speakers u r using working on DC Or AC.
The amp is DC and AC goes to the speakers
can it charge the ipod to?
10 years ago on Introduction
How did you connected the ipod cable to the amp?
Can you please tell me, you inspired me so i don't have to buy a new speaker/dock:P
sorrry for the late answer. i haven't been on my page for ages.
in step 5 on 4th photo, there are 2 female RCA connectors, those are soldered to the amp's audio input (originally 3.5mm female jack).
hey i just saw your project. and it's realy amazing.
but can you explain how you connected the ipod cable to the amp, so I can built it also?? ;-)
This is so badass! Love it!
10 years ago on Step 2
Im going to build this, if you could just please explain how you got all of the boards and switches. Did you just get it off of an old radio or something?
it was already built in this subwoofer. see on 1st photo.
11 years ago on Introduction
The smart point of this project is having efficiently re-used the subwoofer cabinet.
A little more explanatory text would be useful for Instructable clarity.
