Rechargeable Wallet LED Torch(with Usb)
Intro: Rechargeable Wallet LED Torch(with Usb)
This is my first instructable
This instructable will show you how to place a torch in a wallet and charge it with a usb port (very handy indeed
NOTE: i am not responsible if u burn your battery please use correct values or resistors and diodes! do it on your own risk!
STEP 1: THINGS YOU NEED
things you need
-a wallet
-a diode mine was 1n4001
-a resistor( mine was 1k i guess)
-blue/red LED
- switch
-some wires (thin)
-a usb chord having a very thin wire
-a small rechargable lithim ion battery , you will find these in mini helicopters,blue tooth headsets
-a wallet
-blue/red LED
- switch
-some wires (thin)
STEP 2: CONNECTIONS
take the wallet and cut the pouch containing credit cards! wire the led attach a resistor (dont know the exact value). attach the led to the lithium battery.. now take the usb chord and attach a diode
NOTE:place the white end of the diode in the direction of the battery
attach the usb chord with correct polarity with the battery
STEP 3: Attach a Switch
After making the connections attach a switch which you can operate without opening your wallet
you are done
5 minuites charge will last for a long time
10 mins use per day will last up to 4 -5 days(estimated)
you are done
STEP 4:
STEP 5:
my next instructable
attach a cell phone charger in your wallet using anyvolt micro!
please rate the instructable
6 Comments
marshman19 14 years ago
imakethings 15 years ago
helloworld1 15 years ago
