Reclaimed Wood or Pine Egg Holder
Intro: Reclaimed Wood or Pine Egg Holder
This is a nice and easy project to make for your own kitchen, or to give to someone as a gift. If you prefer a more modern style, leave out the ageing and paint with Rust-Oleum 2X spray paint.
The egg holder is made from a piece of pine, but you can also use reclaimed timber or any offcuts that you have lying around.
YOU WILL NEED:
Piece of wood 100 x 250mm + a scrap piece of board
2 handles in your preferred style + screws
Pattex repair gel or Gorilla glue
Gel stain - antique oak
Tools for distressing (wood chisel, file, hammer, etc)
60- and 120-grit sandpaper
Steel wool
TOOLS:
Drill/Driver
25mm spade bit
Quick clamp
Tape measure and pencil
Lint-free rags - See more at: http://www.home-dzine.co.za/crafts/craft-egg-hold...
STEP 1: Mark and Drill Holes
- I marked off the length of the board in 35mm sections with a 20mm border along the long edges. The back row allows for 4 eggs and the front row for 3 eggs. You can increase the length to store more eggs.Draw a line down the centre of the board and then measure 15mm on either side on alternative rows to make the positions for drilling holes with a 25mm spade bit.
- Place a scrap board underneath the board you will be drilling. This reduces the amount of chipping off on the underside and also makes it easier to work.Place the tip of the spade bit on your marks and drill out the holes.Clamp the board to your worktop as you drill to prevent it from spinning.
STEP 2: Rough Up to Create Aged Look
- I used a wood chisel and rasp to roughen up the edges of my piece of pine. If you are using reclaimed timber, or prefer a more modern look, you can leave this step out.
- After roughing up use 60-grit sandpaper against the grain to raise the wood fibers for a more rustic look.
Again, you can leave this out if you are already using reclaimed wood.Give a light sanding with 120-grit sandpaper to remove any splinters.
STEP 3: Stain and Finish
- Use a rag to apply one even coat of Woodoc gel stain to the top, sides and base of the pine.
You will also need to wrap the rag around your finger to apply stain to the cut out holes. - Use steel wool to distress if you want the pine to look aged and even more rustic.
Lightly rub the steel wool over the surface, working with the grain. - Use Pattex repair gel or Gorilla glue to stick your handles onto the base of the egg holder.
2 Comments
Mihsin 10 years ago
I love it, but I'd add a guard rail, wire or plexiglass.
nkapon 10 years ago
