Recycle Old PCB Components
Intro: Recycle Old PCB Components
*Updated
This instructables will show you how to recycle, by desoldering, all your old PCB's (Printed Circuit Board) components. You can find PCB in almost every electronic devices (DVD, computer, camera , toys...).All you have to do is to disassemble them, and desolder the components you want. So here is how to do step by step!
*This Instructable has been feature on Hack-a-Day and in The Best of Instructables book !
STEP 1: Find Things to Disasemble
First you have to find electronics devices like DVD,VHS,Camera,Computer,Clock... that you don't use anymore or that you found in the garbage or that doesn't work anymore.Then remove all the screws and get out the PCB's.(Green plate with components solder to it)
STEP 2: Materials
Here what you need to disolder the components from the PCBs
- PCB s (Of course!)
- Set of pliers (For different size of components)
- Soldering iron
- Vice grip or third hand
- Case for the desoldered components
- Desoldering pump (Optional)
STEP 3: Hold PCB With the Vice Grip
Hold a PCB horizontally with your vice grip or your third hand. Solder side facing you. If you have a regular vice grip, put the solder side , on the side of the hand you use to hold you soldering iron.
If you don't have this kind of vice grip, you can use another type of vice , to hold your pcb up (Pic 2)
You can also use third hand or helping hand to hold your PCB
STEP 4: Start Removing the Components
Get your soldering iron hot and start to remove the components you want with your soldering iron.Put your soldering iron tip on the solder of the component you want, and with the other hand hold the component itself or one of it lead with a plier and get them out when the solder is melted hot. try not to take your time when the iron touch the lead because the component can become very hot very fast and there are risks to blow them up. If the leads are long enough, you can try putting an alligator clip between the component and the joint, the clip will take much of the heat generated by the iron. Check the video for more info.(Video coming soon)
Sometime , you will get to bigger components with bigger lead, to help, you can help you by using a desoldering tool like the one on the picture, its very not expensive, and can help you a lot getting bigger components out. To use it, heat up the lead, then when the solder is melting, put the pump close and hit the button to suck up the solder. Then when you will cock the mechanism back, the sucked solder will come out. Be careful because solder pump have a plastic tip so try to avoid contact with your soldering iron
STEP 5: Continue to Remove the Components
Continue to remove the components with the same technique,and you will get a lot of them!
STEP 6: Recycled Components
Here are the components that I recycled within half an hour of desoldering...
- Capacitors
- Switches
- Audio sockets
- TV plugs
- Resistors
- LEDs
- Transistors
- Motor
- Screws
STEP 7: Recycling!
Don't forget to recycle the parts that you can! Like the metal cases and the plastic panel.But you can also keep them for further project like to make some case.. Recycling is important! Don't forget it !
STEP 8: What to Do With Your Recycled Components? How to Identify
Now that you'v desolder some components you have to do something with them, like build some robots or like nnygamer did, build some computer's bugs with few resistors and capacitors.You can also look at the robotgames contest, there are many things to build with your new recycled components. Like the Jerome's instructables, he builts a bug robot with only few parts, and its very simple to do .Here is the link of his instructables if you want to take a look:
https://www.instructables.com/id/How-to-Build-a-Robot-The-BeetleBot-v2-Revisite/
Here are some other link of project or your parts:
it can help you identify your salvaged components: * http://en.wikipedia.org/wiki/Electronic_components
A good way to regognize your components, is to look at the symbols under the components, then you can refer to shematic symbols on the internet to know what you'v just took out. Look at pics 3 and 4.
We got a yellow copper'd wired thingy that we dont know, just look at its symbol, and you've just realized it was an inductor!
Hope this instructables help you and now go make something awsome!
- https://www.instructables.com/id/Computer-Bugs/
- https://www.instructables.com/id/A-very-simple-proximity-detector/
- https://www.instructables.com/id/Simple-Component-and-Continuity-Tester/
- https://www.instructables.com/id/Resistor-man/
166 Comments
ashb0308 1 year ago
HarrisCreekCentral 14 years ago
The only problem I have is I end up with a batch of parts with little 1/4 inch wires.. The next part I need requires a wire long enough to reach across a two or three hole span in a PC Board.
Has anybody found a neat way to extend those leads..
HLM.
PapaJohn469 2 years ago
--PapaJohn469
goggomobil 13 years ago
I've pulled thousands of components from scrapped electronics. Everyone should keep in mind that components weren't meant to be pulled out of a PC board.
When you heat a lead enough to melt solder, you will likely destroy the part if you are pulling on the part itself and not the lead. If you can't do this because of a short lead, you have to push the lead through the board, but risk damaging the part with heat if you can't apply a heat sink. Electrolytic caps are easily damaged by pulling.
Remember that many components (especially semiconductors) are intended to withstand molten solder for only a second or two. SMD parts should be removed without heat if possible. I chisel them out with a small sharpened screwdriver.
Many parts are very specific to the circuit and others, like toroid cores, are not all alike. Toroids have different ferrite mixes and work over different bandwiths. Some will choke out all RF altogether. Ideally, having the schematic of the circuit explains the component's purpose and value.
Remember to check the pulled part with a tester to ensure it is what you think it is and it's still good. Axial resistors look identical to axial capacitors!
Most of all, wear safety glasses (a tiny blob of flying molten solder can permanently ruin your eye) and don't breathe that smoke!
Patented 14 years ago
ARJOON 13 years ago
beehard44 13 years ago
ARJOON 13 years ago
bears0 14 years ago
---PapaJohn469
naic98 9 years ago
Propane torch, heat quickly and pull part off board
vadipp 12 years ago
TrevorH73 5 years ago
iceng 5 years ago
IF adjustable transformer..
Shielded Intermediate Frequency tuneable radio signal stages..
A metallic iron screw that you adjust with a non-metal screw driver that causes differing inductive coupling with the input coil to output coil and with added pico capacitors can change resonance frequency points.
VoidsMyth 8 years ago
christine.julien.980 9 years ago
Hi, i need our help to search small switch SPDT. I check in printer, radio and computer. I saw big one in microwave but not with plate.
Thank you
Christine
