Recycled Desk
Intro: Recycled Desk
The Goal of this project was to spend zero dollars and build a 24" by 48" Desktop the same height as my bed. everything was found or reused and nothing was purchased.
STEP 1: Gather Materials
For this project I Disassembled Four pallets, removing any protruding nails and discarding any boards that were too weathered or splintered.
I Salvaged several lengths of 2x4"
many 1/2" slats
and a square of 3/4" plywood.
Other materials needed:
Stain/sealant: I found a sun bleached used can of 'stain & seal' half buried in the Dirt behind my dads workshop. It ended up being a nice dark color that really works well with the pallet wood.
Screws, nails, glue: already possessed
Saw
Hammer
Tape measure
Sandpaper
Drill
STEP 2: Some Assembly Required
I Chose a Desktop made up of 12" long slats side by side to create a two foot deep desk. Start by measuring and cutting all of your slats to the desired length. I then played around with the layout and found the best looking sides to make up the desktop. To Create a mounting platform I built a rectangle from 2x4's and cut the plywood square into two pieces that would create a flat surface. The frame and plywood were glued and screwed together. The legs Were created by cutting a 2x4 in half and attaching it to a whole 2x4 using glue and screws. In Order to attach the planks on top I first used a chalk line to give myself a center line then using a generous amount of wood glue I nailed each one four times with a nail gun. A hammer and some finish nails would have worked just as well but much more time consuming. After assembly I sanded the entire piece once over with 120 Grit and the desktop a little extra to smooth it out. I wanted a reclaimed/rustic look so I sanded carefully to avoid removing all the age and character.
Note: The desk has held up well, but after I added a 5 gallon fish tank I had concerns about weight on the desk. I Salvaged two lengths of angle iron from an old rusty bed frame and attached them underneath running the whole length of the desk. The desk is incredibly sturdy now.
STEP 3: Finish
I Finished this piece with an old can of stain and seal combo that I had found lying around. It went on super easy with a foam brush and I am super happy with the color and overall look.
3 Comments
J Stepan 7 years ago
Shadowmang 7 years ago
Unfortunately the stain/sealer combo was discontinued. I had to match the color for another project (Instructable coming soon) and the closest match is minwax provincial 211, the next closest was early american 230 but it was a bit lighter. Make sure to do a test splotch to see if its the color your looking for.
james Stewart 7 years ago
I love the suit enjoy wood work it is so helpful.
