Recycled Portable Bluetooth Speakers
Intro: Recycled Portable Bluetooth Speakers
Hi All,
I feel good about recycling and in this project, I recycled 3 items
- Speakers : extracted from old desktop speaker
- Lithium ion battery from old laptop
- Wood from left over / discarded stack
Features
- Bluetooth / AUX in/ FM/ TF card
- Ultra thin ( just 50mm)
- Volume control
- Remote control
- 6 to 9 hr battery backup
- Weight Less than 500 gms
- Recycles speakers total output : 6 W
STEP 1: What Do We Need
Material
- 2 Speakers ( 3 W each)
- PAM8403 Amplifier with volume control ( 3w+3W)
- MP3 / Bluetooth kit
- 2 Li Ion Battery (18650)
- TP4056 with Battery protection
- 2 DC step up boost - MT3608
- Wires
- PlyWood
- Switch - push button
- Screws ( I extracted these from the original speakers
- 8 screws to hold speakers
- 8 screws to hold the back plate
Tools
- Hammer
- Fevicol / PVA glue
- Black Spray paint
- Soldering iron / wire
- Hot gluegun
- JigSaw with wood blade
- Paper tape
- Sand Paper ( 80, 150 and 220 Grit )
STEP 2: Frame
To hold all the assembly, we will use 10mm plywood.
- Cut a 2 pieces each of
- 45mm X 180mm
- 45mm X 100mm
- Fix them at the edges at 90° as shown
- Use fevicol or PVA glue
- Use paper tape to hold all pieces in place
- Let it dry for 4 hours
- Using 80 grit sandpaper, make the edges smooth and straight
STEP 3: Front Side
- Cut a 180mm x 110mm plywood or MDF ( 4 mm thickness)
- Make 45mm diameter holes for speakers, Note that my speakers were 50mm diameter
- Cut appropriate holes for
- Bluetooth / MP3 plate
- Volume control ( PAM 8403)
- Switch ( Not show in images, as I forgot and I added it while working on the electronic stuff )
- Spray paint black ( glossy) as shown
STEP 4: Back Side
- Drill two hole for 16mm dia meter tube for bass as shown
- Add required holes for TP4056 ( micro usb in)
- and LED indicator ( I use a piece of stirrer for led indicator)
STEP 5: Inside
- Now to fix the speakers, we need to cut a mdf sheet (4mm thick) as shown
- For battery fix two holder as show, we will hot glue battery on these, later
- Let it fry for 4 hours
STEP 6: Electronic
- Follow the logical circuit diagram ( each single line represents both positive and negative wires)
- TP4056 is connected to battery and two MT 3608
- MT3608 is set at 5 V for PAM8403 and 9 V for Bluetooth Kit
- Output from Bluetooth kit is connected to input of PAM8403
- Two speakers are connected to PAM8403
- Test the circuit before Assembly
STEP 7: Putting All Together
Putting all together is difficult and take time, I fixed thing in following order
- Power switch
- PAM8403
- Speakers
- TP4056 and MT3608
- Battery
- Bluetooth kit
Pre-solder long wires to PAM8403, bluetooth kit and TP4056
Hot glue things in place
STEP 8: Enjoy
After all the wiring is done, close the back panel. I used 8 screws to ensure no sound leakage.
Test it using different inputs like FM, USB etc
Improvement for furture
- My speakers were 2w and output 3w, so disturbance at high volume
- Current limited by TP4056 at high volumes, due to high current pulled by amplifier
Please share your comments, if you liked it
28 Comments
VickyF21 5 years ago
What is this?
Amit_Jain 5 years ago
One last question, where is the power switch placed?
Upload on YouTube and send me please
Is the music module restarting repeatedly?
Looks like ground pin is not connected somewhere.
Reduce volume on amplifier and then switch on, donot keep on max
Also try running whole setup on a 5 v charger
* No, the bluetooth kit runs normally
*The ground is already connected & for the volume I have tried but still can't
*Still can't, I've tried
Is there another solution?
If not the wires, i donot know.. sorry
vickyferiansyah 5 years ago
How to set the volt at PAM8403 ?
Surajit Majumdar 6 years ago
Awesome speaker bro :)
Amit_Jain 6 years ago
sleepy120 6 years ago
Dont need 9v for bluetooth. Just bypass the 5V regulator lm7805 on the board and power directly with 5V (short left and right pin with solder).
As a side note, are there any bluetooth modules that default to bluetooth when turning on?
