Introduction: Recycled T-Shirt Scarf
About: I am really into creating. I don't stick to one specific "genre" when it comes to creating. So I do whatever I feel like, and if it turns out nifty, I share it!
This is a super simple way to use up some old t-shirts that you have lying around. It really only takes about 10 minutes to turn an old t-shirt into a super cute scarf! So here is the step by step!
Step 1: What You'll Need
What you need is an old t-shirt (with no seams down the side), a good pair of scissors, and a big tapestry needle.
Step 2:
First cut off the bottom hem of the t-shirt and put it aside.
Step 3:
Now cut the t-shirt into thin strips.
Step 4:
Keep cutting until you reach the armpits and have a pile like this!
Step 5:
Now this is the fun part. Take one strip and stretch it. As it stretches the sides of the loop will curl into themselves.
Step 6:
Which will look something like this after you are done stretching. Be careful if you are using a t-shirt with some tiny holes in it, as it will causes the loop to break. So stretch gently!
Step 7:
Keep on stretching until you get a pile like this!
Step 8:
Now you can either trim the seam off the hem or use a loop that broke while stretching for this next part. But basically you want a string made out off a t-shirt loop.
Step 9:
Take all your loops and hold them together. We are going to use the t-shirt string to hold all your loops together. You do this by simply wrapping the t-shirt string around the loops.
Step 10:
Keep wrapping it around, make sure to hide the starter end.
Step 11:
Keep wrapping until it looks something like this.
Step 12:
Now grab that huge needle and use it to weave in the ends of the t-shirt string.
Step 13:
And you are done! Now you can do a lot with this simple idea. If you had a bunch of loops that broke, you can add beads to them and tie the ends, you can braid them, you can use multiple t-shirts for a thicker scarf, you can combine colors for a multicolored scarf, you can use white t-shirts and then dye them afterward in a ombre style. Really the possibilities are endless!
Don't forget to check out my blog! http://bonafideboho.blogspot.com/
