Redneck Hot Tub
Intro: Redneck Hot Tub
When we renovated an old house a couple of years ago we chose not to have a bathtub in order to have a larger shower but every now and then I miss having a tub just to soak, relax and warm up. There are plenty of examples of DIY stock tank hot tubs out there but this is just my simple, portable version.
STEP 1:
Every time I've pulled up to the local hardware store the past couple of years there's been this 100-gallon Rubbermaid plastic stock tank sitting outside that is almost the exact size as a clawfoot tub. It was only $69 so I bought it.
STEP 2:
I didn't do anything fancy like build a wood facade or make a heater out of copper tubing. The only reason I did it is because when we renovated we installed a tankless water heater so we have an unlimited hot water supply. I just bought a hot/cold tap, pex tubing, fittings and crimp tool which was more expensive then the actual tub!
STEP 3:
The only things I added was a cup holder and clamp mount for my tablet.
STEP 4:
Per my brother's suggestion I did add some wheels later so I can transport it more easily. It's not that heavy but awkward to carry since it's so large. I bought 1/2" steel rod, 6" lawnmower wheels, 1/2" shaft collars and drilled a 1/2" hole in either side of the base then notched it so the axle snaps into place.
STEP 5:
So what I do is fill it up with warm water then leave only the hot tap on so I can just turn on the garden hose attachment when I need to warm it up. I cut a 1-inch overflow hole in one end so it doesn't overflow the top and get my towel wet. The best thing about this DIY hot tub, besides the price, is that its portable so I can pull the plug and store it behind the garage. Thanks for looking!
16 Comments
Jennifer_Gainey 3 months ago
Great minds think alike! I did almost exactly the same thing! I picked up an outdoor tankless hot water heater with decent GPM that runs on propane for under $100 and built a stand for it. I plumbed it directly to the stock tank using a recirculation pump to give the heater water flow. I also added a small filter I found at a thrift store for a couple of bucks. I made a cover for it using insulated bubble wrap to keep unwanted things out of it when it’s not in use. It only takes about 15-20 minutes to get the water from ambient temperature to 104 degrees. I use it two to three times a week and a small propane tank will last me about a month. Best little investment I’ve made in myself in quite awhile! Is it the prettiest hot tub out there? Definitely not! Do I care about such things when I’m soaking in it? Definitely not!
Chainsaw_Cutie 3 years ago
replayreb 3 years ago
BevCanTech 3 years ago
MuzicMaker 3 years ago
I smell an opportunity for some customization - bubble jets or a bubble mat? (The mat has a heater too, might keep you warm with no topping off)
https://www.amazon.com/dp/B005EO2EO2/ref=cm_sw_r_cp_awdb_btf_t1_-F2FFbMYM7PP0
https://www.amazon.com/dp/B0721R63Q8/ref=cm_sw_r_cp_awdb_btf_t1_CK2FFbY8JG97D
jedikitty 3 years ago
My question to you is: how did the wheels and axles fare under a 100 gallon worth of water weight? Curious if they survived or collapsed... I'm currently looking for a tub similar to yours, and might build a wooden crate-like frame (or use a repurposed wooden pallet), and add heavy duty casters.
Dakotamouse 3 years ago
JohnC430 3 years ago
Do you really fit in that tub? Looks like a large compost bin repurposed for this Instructible.
shalnachywyt 3 years ago
jpharkey 3 years ago
