Refill a Printer Cartridge for $5
Intro: Refill a Printer Cartridge for $5
Printers are one of the most popular tools in the world, because they are inexpensive, yet highly versatile. The one drawback is the cost of the cartridges. Two of these can cost as much as a whole printer, and they are difficult to refill because of the new "smart technology" which is built into the printers that keep track of the ink level. Once the cartridge is empty, this technology also will not allow you to simply refill the cartridge with ink, because it will still think that the cartridge is empty. But I'll show you how easy it is to refill your printer cartridge and fool the printer into thinking your cartridge is always full, which allows you to refill your own cartridges with inexpensive ink and save a LOT of money!
For better insight on the project you can view a video on how to do it here !
STEP 1: What You Need !
You don't need many things to refill a ink cartridge,
here's the list :
-Empty Ink Cartridge
-Electrical Tape (any color)
-Regular Black Ink
-Regular Syringe
here's the list :
-Regular Black Ink
-Regular Syringe
STEP 2: Load Ink and Poke
Now getting started isn't hard at all ,
The only thing you need to do is to get the amount of ink u want to refill in ur syringe, and then you need to take a lighter or a open flame and heat up the needle until the top becomes red hot, then be really quick to poke the cartridge in the middle or where you think it's best and start filling up until ink drips out from around the hole
Please view all 3 images to understand the hole process !
STEP 3: Copper Contacts - Geting Around Smart Tech !
This part may seem tricky but it's really easy !
Now most new printers won't let you cheat the system just by putting back ink in the cartridges, since they keep track of ink levels !
In Lexmark's case i found what copper contacts to block out directly from the printer cartridge so that the ink reading will not work anymore , and that the printer will always think the cartridge is always new.
STEP 4: Well Now, :)
Well congrats
Now you can put your black cartridge back inside your printer and start printing and forget about spending a LOT of money on authentic INK !
I told you it was not hard at all and now if u own a Lexmark you really need to stop payng so much money for something u can get for 5$ or less ... :) how much dose regular ink cost anyway ?
The new tech was beat by electrical tape try it and use it well thank you everybody
30 Comments
JaysonB11 8 years ago
With today's printers, you no longer need these things. Just buy an ink refill bottle and refill your printers with default ink tank systems like epson. It's easy and mess free :) inkrefillkits.net
snal 8 years ago
snal. I tried this with Parker ink, in my Lexmark 2250 printer. When printing there were large gaps in the printing, it could not be read. I cleaned the cart & got a nice black line on a paper towel. Put it back in & it did the same thing. Any ideas?
22chrisgirl 9 years ago
I've been doing this for years with my hp's. It works well but, can be messy. WEAR GLOVES goofy! and lol a lot until you get better at it! I've used the same cartridges for years. They'll do great if you seal them in a plastic bag until you use them if your filling several at once as I do. Oh and save your shringe & tip:)
cooldudeintown 13 years ago
lbrewer42 15 years ago
http://www.misterinkjet.com/t-bc02.htm
Look at the technical links in the lower left of the page. They tell you how to reset many different printers to accept your refilled cart's.
Wal-mart, etc. inks are not always good b/c NOT ALL INKS ARE EQUAL! There is no such thing as a universal refill kit. It may or may not work - you take the chance. Due to differences in printhead tech, SOME INKS MAY GUM UP YOUR PRINTER/CART and render it useless - especially these "universal" kits.
1. Never touch the copper contacts by hand.
2. Refilling a cart that has been idle for awhile may not work as it has dried ink blocking the exit portals. However, put a little (proper) ink in the cart, wet a folded (into a small square) paper towel with some water and heat the paper towel in microwave for 30 seconds. Touch the bottom of the cart to try to dissolve/bleed the encrusted ink out. When ink consistently bleeds out - it probably will work in the printer - try it before wasting more ink.
If you used "universal ink" for filling - then this may also be the reason why the printer/cart will not work. After repeating this procedure a couple of times - it may have been the "universal ink" that was your problem.
3. A cart will not last forever and ever. I think the most I ever got from one was 4 or 5 times. Then the printer simply refuses to acknowledge it - I think this is wear and tear. However, I also save hundreds of $$ even with this 4-5 time limitation as the black ink I was using cot me very little in comparison - and cheaper than the 9.97.
4. Make sure you do not cover up the entire top of the cart. Only where the label was (if you remove the label). The small grooves in the top are air holes /pathways to allow air to enter as ink exits - simple physics - need to be there.
5. Get any printer but a Lexmark. No, I am not Lexmark-predjudiced - but it is a fact they gobble up ink quickly as compared to other makes. My HP's use about 1/2 (!) the ink as my Lexmark's (did!). Hence less ink used, ergo more $$ in my pocket.
6. A lot of printers have reset codes to accept a re-inked cart. The websire above has a lot of these listed. I know on my HP All-in-one, I had bought an old cart. at a yard sale - brand new in the box. It would not work. I called the HP help line and told them what was going on. Finally, after awhile the tech on the end of the line told me to:
Press "Enter" and "Menu" simultaneously when the “align printer” message shows. Then go to the Self test page by hitting the menu key- then hit 3 - then hit 5.
She did not realize I knew she was giving me the reset code. I asked her if this is what holding "Enter & Menu" did and she affirmed my suspicions. She said since it was a two year old cart., the printer was programmed to reject it, thinking it was re-inked!
beehard44 14 years ago
RaNDoMLeiGH 15 years ago
d1ndian 15 years ago
J@50n 14 years ago
UltriconConvoy 14 years ago
soonersseth 16 years ago
MonkaySquad 14 years ago
shooby 16 years ago
J@50n 14 years ago
http://www.deluxe.com/shopdeluxe/catalog/facetSearchCategory.jsp?id=STMPINK&flyOut=true
!Andrew_Modder! 16 years ago
tstraub 16 years ago
FrenchCrawler 16 years ago
