Refill a Ballpoint or Gel Pen With Fountain Pen Ink
Intro: Refill a Ballpoint or Gel Pen With Fountain Pen Ink
This instructable explains how to dismantle, prepare and fill a gel or ballpoint pen with fountain pen ink. Although not efficient for everyday use, this will probably be a fun-filled activity for pen nerds everywhere.
STEP 1: Materials
-1 syringe with needle (I got mine from a printer refill kit)
- A set of pliers
- Some fountain pen ink (I used Parker Quink)
- Surgical spirit
- A pen, preferably used ( I used 0.5 ballpoint and gel pens)
- Steady hands
- Several sheets of scrap paper for absorbing any spills
- Gloves
- a disposable cup (optional)
- A set of pliers
- Surgical spirit
- Steady hands
- Gloves
STEP 2: Dismantle the Pen
Take the pen apart, pulling out the ink tube
STEP 3: Take Out the Metal Point and Clean
Take out the metal point:
Grasp the metal point lightly and pull the point out while twisting slowly. In gel pens, the metal point is attached to a plastic portion which, in turn, is attached to the ink-holding tube.
Washing or flushing the tube and point:
Wash the tube and point with surgical spirit, spilling the runoff into a a disposable cup.
STEP 4: Filling a Gel Tube
(The gel pen can be filled without using the syringe's needle)
Suck up some fountain pen ink into the syringe. Place the syringe opening at one end of the gel-ink tube (picture 1) and push the plunger gently. Let an ink column of about 2-3 inches form.
Remove the syringe and let the ink almost fall out and at the moment when the ink column is threatening to fall out of the tube (see picture 2), stuff the metal point back in (picture 3). Wipe off excess ink.
If you see air bubbles, try again.
STEP 5: Filling a Ballpoint Tube
A ballpoint is trickier to fill than a gel tube because of the thinner tube. However, with patience, it can be done.
Suck up some fountain pen ink into the syringe. Position the syringe as shown in picture 1.
Hold the whole tube at an elevation of about 5 degrees (otherwise the ink flows onto your hand). Start pushing the plunger very very slowly.
[Read this whole paragraph first and then proceed] Allow an ink column of 2-3 inches to form. "Balance" the ink column somewhere in the middle of the tube.
Angle the tube slowly, and at the point when the ink is almost spilling out of the tube, insert the metal point into that end. Wipe off excess ink.
STEP 6: Put Everything Back Together
Take the refilled (yay!) pen tubes and put the pen/pens back together. You're done! Try out your new impractical but fun pen, and (sorry for the caps) ALWAYS STORE THEĀ PENS HORIZONTALLY.
I have included some writing samples and pictures below.
I welcome constructive criticism and comments so feel free.
24 Comments
carl.sansfacon 1 year ago
Susen 1 year ago
I keep wondering when these global climate change are going to target all of the oil based products, such as the plastic for pens, that are thrown away?? Also, there really is no 'away' if you think globally.
I'm going to try vaseline, plumbers tape, and rubber cement or Elmer's glue to see if I can fix the leaking problem.
sreeraj 13 years ago
royalfeline778 3 years ago
Half-Life 13 years ago
Recently, a new pen called "butter gel" has been released by the same company for slightly less than that.
www.atlas.lk (their products can be viewed under "shopping cart")
PandaBeaarAmy 9 years ago
Ahmad_rox 4 years ago
what can i do for stopping the ink from coming out from the open end?
EstherT19 5 years ago
atombomb1945 13 years ago
This would be good for those high dollar refill pens.
BTW this fountain-pen-ink mod runs out pretty quickly, and isn't pocket safe.
David AS 9 years ago
Too bad. I literally had the exact same idea, even down to the printer refill syringes and saw that Staples had the Quink fountain pen ink. However, since you said it runs out quickly and is not pocket safe, I will hold off until I do some more research. If only we could get bulk ink that the pen company makes, then we wouldn't have to improvise! That's my next research...
bluebellrose 6 years ago
fastlines49s 13 years ago
AryanB13 7 years ago
can we do ball pen ink pen's ink?
but....... that is great idea but my brother said it can not be done using ink pen's ink
myselfamitabha 9 years ago
When I refill a gel pen the ink is no working. Sometimes work for 2-3 min. after 2-3 min. it stop. Please suggest how to refill a gel pen that works.
oceanRI 10 years ago
This seems like a very logical process to me. I am going to try this soon and then post my results. Thanks for this instruction. Cheers !
