Refurbished Bayonet
Intro: Refurbished Bayonet
My brother left me a bucket of rusted hand tools. Hidden among the odd pieces was this bayonet. This rusted-up piece of metal was just begging to shine again!
STEP 1: Sanding and Sanding and Sanding Some More....
I used a series of very rough to finer grades of sandpaper, elbow grease, and a polishing wheel to remove all the rust.
STEP 2: Pick the Wood and Bring to It to Round
I chose to use birch. I love the feel and look of this hardwood and it is easy to work with while it maintains its strength.
I turned the piece on my midi-lathe after cutting the block to length.
STEP 3: Half That Sucker!
Using my table saw, I bisected the rounded piece of birch. I set the blade height to cut only half way through to I could safely maintain the blade/wood orientation.
The handle shaft outline was transferred to the interior of the cut round and the wood was removed to accommodate the handle shaft.
STEP 4: More Sanding & Shaping
Using a belt sander, the two halves are shaped into a more ergonomically-pleasing shape. I kept checking and rechecking to ensure the wood handle would meld into the contour of the metal components.
STEP 5: Drill & Glue
I drilled matching holes in the wood pieces and the internal metal shaft to accommodate two shaft pins. I dry-fit all these pieces to ensure no surprises once the epoxy came out.
I epoxied the wood, the shaft, and the shaft pins. Then I clamped it together and I left it to dry overnight. The blade was taped to avoid getting any epoxy on it.
STEP 6: Even MORE Sanding....
The shaft pin screws were set and a final, fine-grit sanding took place all over the handle.
STEP 7: Stain & Smile!
I applied a final stain (Early American), wiped it dry, and let it cure in the beautiful Montana sun!
I am very pleased with how this project came out. It looks great and feels very solid in my hand. I believe this was a M4 bayonet from World War II.
16 Comments
paul the maker 8 years ago
a real Halloween prop you have helped me allot refurbishing my stuff aswell
BooMaster 8 years ago
thanks for the reply
EliasT 8 years ago
Pygar 8 years ago
MandalorianMaker 8 years ago
Pygar 8 years ago
Nice- but a soak in vinegar would have saved a lot of sanding... Next time, right?
DIY Hacks and How Tos 8 years ago
Nice restoration
came6920 8 years ago
RussellG10 8 years ago
A bayonet is the blade that attaches to te end of a military rifle. (Like the one hes working on)
3366carlos 8 years ago
windego 8 years ago
hi there Nice job I like restoring old metal also.The vinegar trick mention by Pygar really gives a good result,you just soak in white vinegar for 24hrs give a rush over with a tooth brush rinse ,dry and finish off with a fine wire brush you will be amazed
powerfulparadox 8 years ago
