Regular Rubberband Knex Bow
8,385
13
54
Introduction: Regular Rubberband Knex Bow
About: I seem to like building crossbow shaped objects.
I said in my group that I will post this, so here it is.
I was fiddling around with my crossbow and came to this.
This is a normal bow that uses a chain of thick rubberbands, so it needed to be very sturdy and after i made it very sturdy, I believe it will even survive if you let it fall down the stairs.
I found that it was near impossible to let it shoot grey knex rods, so I chose for wooden or plastic arrows.
NOW FINISHED
_______________________________________________________________
The camera works better in daylight :D
And is even better then on the pictures i posted :P
________________________________________________________________
Step 1: Build the Inner Frame
You might be very familiar with this part if you made my crossbow.
Pic 1: Bottom halves of inner frame (dont forget to stick on the green rods :P)
Pic 2: Top halves of inner frame
Pic 3: Combined halves of inner frame
Step 2: Combining Inner Frame
This step can be very hard, you can make this however you want, as long it sturdy.
If you try mine then here are some pictures
Step 3: Making Bow Sturdier
pic 1: Just add the rods as shown in the pictures(Please use Yellow rods instead of the Red rods!)
pic 2:
pic 3: Add this to both sides
pic 4: Add all these damn pieces on the other side aswell, after that connect the green rods first, then see next pic
pic 5: Add the white rods including the grey connectors
pic 6: This is how it should look like by now
pic 7: You want 8 of those things
pic 8: Add them to the grey connectors on the front
pic 9: Put them on the back aswell
pic 10: Make these
pic 11: Make 4 of those
pic 12: Connect it together
pic 13: Take the yellow rods with wheels off and put the very thick rubberbands around them
pic 14: Stick them back in place
Step 4: Loading and Launching
Slide your arrows through the hole in the middle and then against the rubberband and pull it back.
Do not fire at siblings :P
And do not fire at living things either, cause if you use proper arrows you may injure them XD
Be the First to Share
    • New Year, New Skill Student Design Challenge
    • Jewelry Challenge
      Jewelry Challenge
    • One Board Contest
      One Board Contest
    54 Comments
    zap89
    zap89
    13 years ago on Introduction
    REGULAR, ARE YOU SERIOUS, THIS THINGS GINORMOUS
    Shadowpom
    Shadowpom
    Reply 11 years ago on Introduction
    a compound bow is the same size as this and a recurve/longbow would be alot larger
    Trogador
    Trogador
    Reply 13 years ago on Introduction
    He meant regular as compared to his crossbow.
    something94
    something94
    12 years ago on Step 3
    do i need all those light grey connectors cas i only have enough to cover half of the lower arm
    Wicky
    Wicky
    Reply 12 years ago on Step 3
    You can use red or green connectors instead.
    PS: What a horrible camera I used, I am surprised you can build it =d
    Wicky
    Wicky
    Reply 12 years ago on Introduction
    Nothing spectacular, guess about 70 feet? Not my greatest weapon =/
    Raz1r Knex Bull3t
    Raz1r Knex Bull3t
    if you have watched lord of the rings try making a elven bow out of knex or just make legolas's bow out of knex
    frozendragon
    frozendragon
    12 years ago on Step 4
    nice i have to go outside to get some arrows lol
    F I S H
    F I S H
    13 years ago on Step 1
    its a bit hard to build with those pics.. =\
    PieMan1357
    PieMan1357
    I thought of a way to make the arrows. super glue 2 gray rods together and sharpen the front of it. Just an idea.
    Wicky
    Wicky
    Never thought of that...I don't think the super glue will hold the arrow in one piece though...as from what I have seen Knex bends alot when fired upon something using great force. I never have any super glue though :P
    magician847
    magician847
    13 years ago on Step 4
    How do u make knex arrows for this bow? i tried but they allways break
    Wicky
    Wicky
    Reply 13 years ago on Step 4
    Like it says on the intro, it does not fire knex, but you could try a long piece of thin round wood. I found one with a sharp point on it :P
    pls
    pls
    looks like it would also be affective just flailing it around at someone.
    Wicky
    Wicky
    It could be, but you can't move it quick since it weights alot lol Hmmz, that would it a ranged AND melee weapon :P Just look at this picture(it must be in this instructable somewhere), this would be even more effective :o(Just push all those red rods up) :D
