Remote Controlled Bot With Atmega8
Intro: Remote Controlled Bot With Atmega8
It is a bot controlled using your any tv remote controller.
We all know that tv remote has one ir transmitter which transmit data to the tv.
There is one ir receiver called TSOP which receives ir signals and send to controller.
Our Bot works on the same principle. For controller we use an arduino older with atmega8 chip.
STEP 1: Component Required
1. TSOP any value
2. Arduino Atmega8
3. Batteries
4. Motor Driver
5. Dc Motors geared
6. Wheels
7. Wires
8. Leds x2
9.Programming Cable
10. Arduino IDE
STEP 2: Making Connections
Make the Connections As shown in the image.
Assemble the bot and connect the tsop at top for better response.
STEP 3: Install Library
Open Arduino IDE
Move to
sketches>include library>Add zip library
then choose the zip file
STEP 4: Install Hex Code
Upload hex code to arduino and get hex values for your remote. All values are different for different remotes.
After uploading hex code goto serial moniter to see the hex values of your remote button.
In my case values are like shown in image.
Convert the hex code to decimal value. For conversion use google or any app on playstore.
STEP 5: Installing Final Code
Replace your remote values with the values in if condition.
You can choose your own buttons to operate bot.
STEP 6:
https://m.youtube.com/watch?v=NDETDTPsVnE
