Remotely Control Your Raspberry Pi Via SSH
Intro: Remotely Control Your Raspberry Pi Via SSH
Learn how to control your raspberry pi remotely with your cell phone via the SSH protocol. Thankfully the Termius app, available on Android and Apple stores allow us to set this up with ease. I will walk you through the setup in this tutorial.
Before reading the remainder, be sure to subscribe and support the channel if you have not!
Subscribe:
Support:
https://www.buymeacoffee.com/mmshilleh
Hire me at UpWork to build your IoT projects:
STEP 1: Prepare Your Raspberry Pi for SSH Access
Before you can start controlling your Raspberry Pi remotely, you need to ensure that SSH (Secure Shell) is enabled. SSH allows you to access your Raspberry Pi over the network securely. Here’s how to enable it:
- Boot up your Raspberry Pi and open the terminal.
- Enter sudo raspi-config to open the configuration settings.
- Navigate to "Interfacing Options" and then to "SSH."
- Choose "Yes" to enable SSH, then select "Finish, " and reboot your Pi if required.
STEP 2: Find Your Raspberry Pi's IP Address
To connect to your Raspberry Pi, you'll need its IP address. You can easily find this by using the ifconfig command in the terminal. Look for the 'inet' line under the 'wlan0' entry if you are connected via Wi-Fi, or 'eth0' if you’re using an Ethernet cable. This line will display your Raspberry Pi's local IP address.
STEP 3: Setting Up Termius on Your Smartphone
Now that your Raspberry Pi is ready for remote access, let’s set up the Termius app:
- Download and Install Termius: Grab the Termius app from your phone's app store and install it.
- Add Your Raspberry Pi as a Host: Launch Termius and tap on the 'New Host' button. Here, you will enter your Raspberry Pi’s IP address that you noted earlier.
- Enter Credentials: For authentication, input your Raspberry Pi's username and password. The default usually is 'pi' for the username and 'raspberry' for the password, unless you've changed it.
- Connect and Control: Hit the ‘Connect’ button. Once connected, you’re ready to execute commands on your Raspberry Pi from your phone, just like you would from a traditional computer terminal.
Enhancing Your Experience
This setup not only enhances your productivity but also ensures that you can manage your projects even when you’re away from your desk. The security of SSH also means that your commands and data remain encrypted over your network, keeping your Raspberry Pi secure.
If you found this tutorial helpful, please consider subscribing and supporting us. Your engagement helps us to keep sharing useful tips and tutorials.
Are you embarking on an IoT project and need some expert assistance? Hire me on UpWork and let’s bring your ideas to life together!
