Remove a Security Tag From an Article of Clothing
Intro: Remove a Security Tag From an Article of Clothing
I'm really not surprised a store forgot to do this, but in the end I was left to dealt with this.
When my Mom brought home her new pair of gloves, which she paid for not stole, she went to use them and found that the security tag (non-ink one) was still attached.
The following is a simple and very useful instructable to free your clothing articles.
STEP 1: The Enemy and the Weapons
Here you have it. The super tight miniature pin that locks this device in place.
You won't need much if you have the proper tools.
- Ice pick or sharp skinny object (a pocket knife will work fine here)
- A pair of horse nippers. I highly recommend keeping a pair of these around at all times. They are basically a huge pair of toenail clippers, but super sharp. (heavy duty wire cutters will also work here, but might be a little harder to work with).
- A skinny flat-head screwdriver.
STEP 2: Remove the Node
Start by taking your clippers of any kind and snipping the node off the back of the security tag. This might take a couple attempts, but removing as much as possible here will help you later.
STEP 3: Remove the Foil
After snipping the plastic back, you'll find the culprit pointing through, a tiny spike of metal. Around it you'll also find a shinny piece of paper. Take any sharp object and scrap to remove this. You need direct access to what's beneath it.
STEP 4: The Final Step - Leverage
There's only one last thing to do.
Take your skinny flat-head screwdriver and pry up just one side of the security tag. This is made of some high strength steel, like spring steel, and will take more effort then it looks.
You don't need to budge it much before the pin slides right out of the tag.
That's it!
That's it!
31 Comments
Lftndbt 16 years ago
platinum15 14 years ago
floydaroo 6 years ago
a security tag that sprays ink unless removed at the store (search for it in the let's make box
PedroV97 7 years ago
Thanks for this, I had no clue how to remove it without damaging the item. We went through a self-checkout and the tag didn't beep on the way out, and the checker was only interested in counting the items in the cart to compare what was in the receipt. I could have wasted a 28-mile round trip because of the stupid tag.
CarolC5 8 years ago
John_the_Builder 10 years ago
I bet if you return the item and make a huge fuss, they will give them to you at no cost. With the price of Fuel these days, having to drive back to a store to have a security device removed could cost more than the item did. Tell them, it's their mistake, why should you pay for the trip back.. Just my opinion. Of course if it's a $100 item they may not. A discount would be ok...
I had them do this to me, but it was a DVD.. I went crazy removing the security device.. I ended up cutting it off with a dremel tool.
I recently built a TV remote control kit, and for some reason every time I enter, or exit a store, it sets off their Security Alarms. I'm guessing the bare circuit board is mistaken for a security tag... Anyhow, I finally had to stick my project inside a small electronics part baggie. The Anti-static nature of the baggie blocks the alarm from going off. Now I can go into stores with impunity and turn off All their TV's using my made remote. It's harmless, after a few minutes they turn back on since they are in Retail Display Mode. It's just funny to watch people when the entire wall of TV's turns off... I'm the Diet Coke of Evil.. All the Flavor, but only 1 calorie.. Ha ha.
xina15 10 years ago
poofrabbit 11 years ago
mcorcoran 13 years ago
Thanks again!
TheRMSDave 13 years ago
Knowing what I now know, it would've been faster to insert a can opener (the kind that punches a hole in a juice can top), large pin or small nail with a curved tip through the plastic right beside the pin (narrow side) to press the tabs upward to release it.
The second method would be to turn one piece ninety degrees relative to the other and use two pairs of pliers to grab the ends of the smaller rectangular piece. Simply bend both ends downward over the portion containing the ink, curving the clip until the slit opens enough to release the pin.
ParkerK 13 years ago
ThinkBeforeYouSpeak 14 years ago
chriselite 14 years ago
robinw13 14 years ago
M.Hunter 14 years ago
teknoman 15 years ago
bwpatton1 15 years ago
