Removing Black Stains in Wood Furniture With Oxalic Acid
Intro: Removing Black Stains in Wood Furniture With Oxalic Acid
Iron oxide stains in wood are usually dark spots caused by prolonged exposure to water and / or metal. The iron oxide reacts with the tannins in the wood and stains it black. Wood can intentionally be stained black in the same way, and that's called Ebonizing.
Along the edge of my desk I kept a rusty metal ruler, and sometimes I would over-water the plant on the desk and the water would pool up under the ruler. In a short time this lead to black stains all along the edge of the desk.
I've seen some amazing results from furniture restorers using oxalic acid to remove such stains, but I couldn't find it locally and never got around to ordering it online.
One day I came across a How-To by Thomas Penrose and realized that I already had oxalic acid in the form of Bar Keeper's Friend. A big thanks to him for the write up. I'm going to relay those basic steps and add some tips of my own.
Materials and Supplies:
- Bar Keeper's Friend or similar powdered metal polish containing Oxalic Acid (Red Bear, etc.)
- Water
- Paper Towels
- Chip Brush (optional)
- Plastic Paint Scraper
- Stiff Nylon Brush (optional)
STEP 1: Assess the Stain
If the stain is dark, almost black, chances are it's from water exposure, but it could also be from ink etc.
If the stain is dark red, it's probably from wine or food or anything else.
This method will only work to remove dark iron oxide stains. It won't hurt to try, but it'll probably be more effective to bleach / sand / refinish other types of stains.
If the wood has a polyurethane finish or other surface coating and you see a stain, it's stained underneath, and that coating needs to be removed first.
If the piece has an oil finish or if it's raw wood, you don't need to do anything to prep the surface.
STEP 2: Make a Paste With Bar Keeper's Friend and Water
Add some water to Bar Keeper's Friend until you have a consistency that you can work with.
The ratios aren't important, but you don't want it to be too wet. Excess water is just going to raise the grain. All you need the paste to do is sit on the surface of the wood. You don't need it to soak in.
STEP 3: Wipe It On
Always test on an inconspicuous area first!
- There shouldn't be any negative effects, but it's good to find out on a small area instead of the whole surface if there is.
For the first application, target the stains.
Wipe or brush it on and then wait until it dries (15-30+ minutes).
As it's drying, you should see the white paste turn slightly yellow. This is good.
STEP 4: Scrape It Off
I scraped the dried mixture off and vacuumed it up rather than wetting the surface and wasting paper towels.
After the first application you should already see a huge difference. If not, then this method probably isn't going to work on the stain.
STEP 5: Second, Third, Fourth Applications
Mix up another batch and apply it the same way you did before.
When the stains are mostly gone, you'll notice that the area you cleaned will be lighter than the surrounding areas.
For the next application apply the mixture to the entire surface of the piece to help blend it together.
STEP 6: The End Result
I only needed 3 applications to get the stains to a point where I didn't mind anymore. Further applications will remove the stain completely. My plan is to refinish the top of the desk at some point, first by applying oxalic acid to any other stains, and then rubbing with #0000 steel wool and oil to clean the dirt while leaving most of the patina that's built up since I've owned it.
Final Tips:
- Because Oak has a very open grain, a lot of the mixture will be stuck in the grain of the wood. I used a stiff nylon brush in a circular motion to remove it. This probably isn't necessary on other species of wood.
- If your refinishing process involves steel wool, be really careful to remove all of the metal shavings from the surface, especially with Oak. It's recommended to use brass wool or synthetic wool to avoid this. When the metal particles get wet in the future, it will just start the whole staining process over again and you'll have to redo it. In practice steel wool is fine, just make sure to blow the piece off with compressed air and buff it with a microfiber to remove all of the shavings.
- When sanding, don't sand too deep. As you cut further down into the surface you might expose more of the stain, and then you'll have to reapply oxalic acid all over again.
22 Comments
trishkinter 1 year ago
Lf 1 year ago
prevent the water from penetrating the wood and avoid getting the spots in the future after we remove them? Any special coating that you recommend?
jayphansen1 1 year ago
Question: what's the best way to remove a clear, satin finish on light colored oak flooring?
david haimson 1 year ago
resamaggiematt 2 years ago
PennyC55 2 years ago
marcusarchitect 3 years ago
rebagogo 4 years ago
FedexM 5 years ago
mobdesign 5 years ago
SusanB324 5 years ago
I have to say this technique was truly AMAZING! I did some canning last weekend and put my case iron skillet on the table next to the cooling rack forgetting that sometimes they leak. When I went to move it a few days later the cast iron skillet was stuck to the table and had left a HUGE 12" black circle a few inches wide where it had sat. I quickly tried a few other things which took some of it off but not much so I Googled and found this tip. No more ring and practically no effort. Wish I had taken a before picture but this is the finished product. I have taken added a picture of the bottom of the pan. See the rust that is how big the stain was on the table.
MissyL13 6 years ago
Hi. Great tutorial It totally worked but the black on my counter has come back. Any advice on how to keep it form coming back? I have done it twice now and the stains just keep appearing about a week later.
Thanks,
Missy
dlager 7 years ago
Wish I had seen the lemon juice idea first. A lot of powdery residue got stuck in the oak grain of the table leaves I was working on (not the main table top for some reason). Maybe it was because the grain on the leaves was more open due to stripping off the varnish right before applying the Bartender's Friend. I plan to continue trying mineral spirits or water and a stiff brush to dissolve or brush it out. It is not coming out easily. If I can't get it all out, will it cause a problem with staining and varnishing?
dicandoit 7 years ago
DRAGUA1979 7 years ago
sunspotbaby64 7 years ago
regular clorox bleach will remove the stain.No matter what you use though,you will have ti restain the the wood.After bleaching the stain damage,you need to rinse the wood really good with water.Let dry a few days.Sand and then stain.Then put on a sanding saler,sand,then apply two finish coats of polyurethane
Evelyn348 7 years ago
timely advice, I have wooden clothing racks for drying clothes outside and was wondering what I would need to do.
ooohlaa 7 years ago
we all have to remember to choose the least toxic method for all approaches to life's problems, i.e., start with lemon juice ... it might take a few doses but better not to breathe fumes of anything, we already do from outdoor air, to public bathrooms, to department stores, to golf courses etc. we are always breathing in toxicity. that being said I would use this method and am grateful for it, if must be! thanx
foobird 7 years ago
Take care when using Oxalic acid. It is poisonous.
momoluv 8 years ago
I didn't even know those stains could be removed! Great job :-)
