Removing Honda CRX Stock Air Intake & Resonator
Intro: Removing Honda CRX Stock Air Intake & Resonator
The resonator box and intake extension are basically made to quiet the intake, they also restrict air flow into the engine. To make things worse the extension piece is positioned right on top of the header which means it’s basically sucking in hot air.
Removing the whole assembly isn’t going to do a huge amount of anything performance wise, but since I have to wait until after my engine swap to add a proper cold air intake this is the best I can do.
Since I had the whole bumper off to fix a headlight anyway, I decided to remove everything.
Taking off the bumper is a pain in the ass and I haven’t done a write up for it yet, but I will eventually, until then you’ll have to figure it out yourself.
STEP 1: Step 1
While it’s off you can always get a lovely assitant to carefully scrape nasty bugs off your radiator. Be prepaired to answer questions like; “How big are the UNUSUAL bugs in B.C.?”
“Jebus what the Heck is that?”
STEP 2: Step 2
The extension piece is bolted along the top of the radiator by two bolts (I’m pointing to the right one their’s another one off to the left)
Once those bolts are off you can just pull the extension out, I put the bolts back into their holes, just in case I need them for something later
3 Comments
hYu 10 years ago
The resonator actually makes your car more powerful. It provides a expansion chamber for pressure waves to dissipate when you suddenly close the intake valve and other back pressure waves from the cylinders etc. so that when the engine does need fresh air again it's not fighting the back pressure waves. But whatever, just disregard the hundreds of engineers and people that are involved in designing a car 'cause I'm SURE you can build a car from scratch if you wanted to.
kboard 12 years ago
ThinkBeforeYouSpeak 14 years ago
