Repair G-shock With Paracord Bracelet
Intro: Repair G-shock With Paracord Bracelet
I use this G-shock for 4 years and it worn out.
For the first replacement, I use a 20mm PVC pipe to replace the locking looper, it work quite nice.
But I think the band also worn out significant these days, so I need to replace the band also.
I watch quite a lot about paracord bracelet but I sure that I can not make one.
Finally, I buy a paracord bracelet for US$ 2.5 (HK$ 20) and tie the G-shock on it.
I think this replace is the most easy and unique.
Cheers
Some Comments on this method.
1. I use another rope (brown in color, smaller diameter - necklace) and tie some decorates at the end.
2. Paracord bracelet is heavy (when compare to watch band, probably similar to those metal band), so u did not feel there is a significant weight change after u tie compass/ thermometer....
3. For the same way, u can install small gadget on the bracelet or even insert memory card to the slot under the compass, or.... 3D print some...
2 Comments
seamster 9 years ago
This looks like a great fix!
I'm sure you could make a paracord bracelet! You should give it a shot some time, it's not too hard.
kokpat 9 years ago
Many Thx.
