Repair Leaked Water Dancing Speakers
41,191
21
14
Introduction: Repair Leaked Water Dancing Speakers
About: Hi, I'm Christopher Sales. I'm now 17 and a hobbyist. I started making things with cardboard at 4, lego at 8, weapons at 9, mechanisms at 12, and electronics at 13. I love making weapons of self-defense, and o…
Hi, this is my first ible!
I bought these Water Dancing Speakers a year ago, and they worked great. But for some reason, one of the speakers broke, and the water inside it was emptied. I checked online for a solution but found no threads or instructions on how to repair them. So, if you're like me, I hope this helps!
Step 1: Tools You'll Need:
Here are the tools I used:
-An electric drill with a 1.2mm bit
-A syringe with a needle
-A philipps screw driver
-Epoxy/a waterproof sealant
Step 2: Disassemble the Speakers
Mine has 4 screws outside and 5 more inside. The board essily slid out and so as the transparent plastic part with the motor. The only part held down was the speaker. After removing the speakers, you can work more freely.
Just unscrew 2 more holding the motor in place and we're good.
Step 3: Refilling
I first drilled a hole 1.2 mm wide under the box. After drilling, I filled up the syringe, inserted it to the box, and than injected. It took me about 5 refills with my syringe. Just lay the other speaker(if it's not broken as well), beside the one you're fixing and use it as a guide.
Step 4: Sealing the Hole You Just Made
I sealed the hole with a two-part epoxy. You may use a sealant or caulk as long as it stays on and doesn't leak. Let it dry.
Step 5: Reassembly
NOTE:When reassembling, align the magnets on the rotor of the motor to the wheel's inside the transparent box.
I simply reassembled it after the sealant dried and you're good to go. Make sure you place all the parts correctly, because the lid might crack easily. They're still upside-down just to let the sealant dry more.
If you found this helpful, please vote for this. Thank you so much!
I hope this was helpful. Thank you!
DIY University Contest
Fix & Repair Contest
Tech Contest
Tech Contest
2 People Made This Project!
  • Science Fair Challenge
  • Trash to Treasure Contest
  • Origami Speed Challenge
14 Comments
rjtthree
rjtthree
7 years ago
Hi cris. Great job! I'm a proud owner of the water dancing speakers too. I was wondering if you knew what type of plastic they are i want to resurface mine and Im not sure. I want to be sure before as to not compromise the speakers they are hard to find. Ty for your help
CRAZYFA
CRAZYFA
Reply 4 years ago
OMG 2 YEARS I WAS ON A HIATUS I'M SORRY I THINK IT'S TYPICAL ABS PLASTIC☹️
shannonw52
shannonw52
5 years ago
Any suggestions on how to fix this? Went to plus the speaker in and noticed the thing missing, opened it up to find it has come off. Can i glue it back on or is it broken?
CRAZYFA
CRAZYFA
Reply 4 years ago
One year late huhu I was on a hiatus for 3 years! Well you can glue it back however if it fails, I suppose you can find a replacement or just buy new ones☹️ But an adhesive will do the trick don't worry?
Kshitijs29
Kshitijs29
4 years ago
How to make a mp3 water speaker at home plz plz tell me
CRAZYFA
CRAZYFA
Reply 4 years ago
HEY! I just got back to Instructables with this account after years of doing nothing! Well it's fairly simple, all you need is an enclosure, speakers with a powerful bass, and a lot of water-proofing and leak proofs! I'll take it in mind and make one soon:)
LashaG
LashaG
6 years ago
can you take circuit pictures , i want to do that myself ;)
OfficialGarcia
OfficialGarcia
6 years ago
Where can I get A syringe with a needle
CRAZYFA
CRAZYFA
The original liquid's called Mineral Oil. I used water, but it doesn't work that well. You can get it from a drug store, or you can try clear baby oil.
petercd
petercd
Nice fix dude, worth adding to the fix & repair contest
CRAZYFA
CRAZYFA
Reply 7 years ago
Thank you, sir!
Makersauce
Makersauce
7 years ago
hey add it to a contest!
