Introduction: Repair Logitech G602 Wheel-button
A while ago, my wheel-button stopped working randomly. After some while, it stopped working completely, so I repaired it (and made it indestructible).
What you will need to repair it yourself:
- soldering Iron
- solder
- pliers
- 6mm*6mm push button
- phillips screwdriver
Step 1: Opening the Mouse
To access the screws of the G602, you will need to remove the gliding pads. Be careful when doing this and get completely under the glue-pad to prevent seperating it from the gliding pad.
Now you will be able to see the screws. Remove them.
Step 2: Remove the Old Button
After you opened the mouse, you will see a white pushbutton. Apply a bit of solder to the legs to improve thermal conductance and desolder the button. Alternatively, you can cut the leads and desolder them invidiually.
Step 3: Solder the New Button
Now you can solder in the new button. I used an SMD button because I had them laying around. I suggest using SMD buttons because you can just bend the leads under the case and solder it without having to empty the solderpad holes. The orientation of the button is crucial since two leads are always shorted together. Just keep it the same orientation as on the old button.
Step 4: Reassembly
Just put the case halves together and screw the phillips screws in.
Ta-da! Your mouse-wheel button works again!
49 Comments
Tip 1 year ago
DUDE YOU ARE AWESOME!! So i was just about to order this untill i looked in my junk drawer for something that may have had that switch in it and found a ps4 controller that was bought new but did not work that i never could figure out how to fix. So the joysticks when pressed down actuate this exact switch so i tore that puppy apart and got two brand new switches out of it and replaced the switch like u said and have an extra incase it breaks again. Now the mouse is working like it did when i bought it. only now the switches in the ps4 controller are MUCH better quality.
1 year ago
I 2nd Mark's "blow job" technique. I used shop compressed air to no avail. Even opened the battery door & shot air inside, feeling it exit through the mouse wheel. Didn't work. About to shop for new mouse, but gave the "BJ" a chance. Worked!
5 years ago
Same problem here before I started dismantling the mouse I tried blowing in the wheel hole. Cover the hole with your mouth and blow hard. Strangely enough it works perfectly. It isn't a permanent solution as the problem returns but it works for a while at least. Seems a good blow job can cheer up your mouse too.
Reply 2 years ago
I can't believe it worked so good! Just registered to say thank you
Reply 4 years ago
This is two years old and I am still getting nice comments glad it helped you guys!
Reply 4 years ago
Yup, it works. Registered to say thanks as well :) Was minutes away to getting it back to the shop for repair.
Reply 4 years ago
I am so glad I found this comment!! I was getting ready to buy a new push button. Works perfectly now. I hope this fix works every time that button starts to act funky.
Reply 4 years ago
It worked instantly :D
Don't have to remove the glide pads anymore!
Reply 4 years ago
omg it actually works!! thanks so much
Reply 4 years ago
I tried it and it instantly worked again. Thank you, now I wont have to replace it.
Reply 4 years ago
OMG. Worked remarkably well. Registered just to say that. Thank you!
Reply 5 years ago
Honestly, i wish i read this comment first. I went through with replacing it, didn't like the click, checked the old one to see if it still worked, reinstalled it, lost several screws, dropped screws back into the mouse, etc etc. turns out that taking it apart and cleaning it (blowing on it) made it work. Cheers.
Reply 5 years ago
Also logging in just to say thanks!
Thank you!
Reply 5 years ago
Same here, just register to say thanks. a good blow and problem solved haha!
Thanks mate!
Reply 5 years ago
I also just registered to say thanks!!
I blew it once and (so far) it seems to be fixed. This is amazing.
Thank you so much
Reply 5 years ago
Lmao that worked like a charm mate. Didnt expect an easy fix
Reply 5 years ago
wow i didnt expect this would work, can anyone explain for me why just 1 blow on the wheel and the middle mouse button works again?
Reply 5 years ago
I registered to say THANK YOU. My wheel was stiff and hardly moving. I was about to break out the tool set but all I had to do was act like the big bad wolf. Thank you!
Reply 5 years ago
oh my god, registered just to thank you! i've been using this mouse for almost 3 years now and i would hate to throw it away or damage it when trying to repair it. but just blowing on the scroll wheel works! so stupidly easy! you're a real life-saver. thank you so much!
Reply 5 years ago
Registered just to thank you. It is working!
