Repair Your Clogged Coffee Maker
Intro: Repair Your Clogged Coffee Maker
Don't throw away your coffee maker just because it only makes steam and has stopped gurgling water up into the brew basket. I have repaired a couple coffee makers by forcefully spraying water into the "fill area".(Unplug first of course). This clears the pipes going down into the heating element area. This method didn't work on my expensive MR-COFFEE machine. So i was forced to remove the cover and find what was clogging it up. This is not very hard to do and you don't need many tools.
OTHER BRANDS are built similarly to the Mr. Coffee. If you are trying to fix some other brand or model all you need to do is find out what is clogging the hose --- as I describe here --- and your repair should be similarly easy.
STEP 1: Preparation to Fix Coffee Pot
SAFETY first, so unplug the coffee pot and LET IT COOL DOWN (if you had it on)! This will help you avoid burning yourself on the hot-plate. Next....dump out all the water left in the water-resivoir into your sink. Try to be rather thorough to get ALL the water out because it will be necessary to turn the machine upside down to remove the bottom..... and you don't want puddles of water dropping into the display-board-section.
STEP 2: Tools You Will Need:
You don't need many tools but one of them is somewhat difficult to find... the SECURITY torx bit. I bought my set of SECURITY-torx-TIPS at harbor freight tools for only a few dollars. The security torx is just a standard torx screwdriver bit with a HOLE in the middle and a little pin. You will have difficulty removing 2 of the 6 screws on the bottom because they are "security" type torx. The other 4 screws
are standard phillips. Another way to get the 2 security torx screws out that might work is to use a SOLDERING IRON. Just heat up the torx screw untill the plastic melts then pull the case apart. Of course, you will need to have all the other screws out first!
STEP 3: Down-spout Removal & Fix
The downspout hose is easy to remove. Just pull on it! The other hose is the UP-spout.
STEP 4: Something Looks Funny Here!
Other coffee pots just have a hose... but the Mr-coffee has a VALVE inside the hose. It is a valve that controls the water flow... but this valve is very small and clogs easily. Mine had a small piece of coffee residue sticking to it that kept the valve clogged. Just remove the gunk... and that fixes the clog! To remove the valve... just squeeze the hose and it pushes right out. When installing the valve, be sure to put it back RIGHT SIDE UP. The next step shows a close up of the valve so you can see what to look for.
STEP 5: VALVE Cleaning and Replacing:
Notice the little ball inside the valve. It sits on top of a few little pegs that hold it up so water can flow around it. This is right side up. If you turn it around the other way, then no water will flow. If you install it backwards, just re-do the whole procedure and turn it around.
STEP 6: Finish Up the Repair.
Re-attach the downspout and put the bottom back on. When I finished my "simple" repair, the coffee pot would not turn on properly! It seems I got some water into the display-board area. So i quickly unplugged the appliance. No harm was done because I dried the upper-board out, using my wifes hair-dryer. DON'T OVERHEAT it... I just mildly heated the front and sides of the coffee pot for about an hour. This evaporated the moisture inside the front control panel. Alternatively, if you have this difficulty you could also just set the coffee pot aside and let it sit for a few days for the moisture to evaporate. If you suspect any water got into the upper display/control circuits, then let the coffee pot sit to dry out for a couple days before plugging it back into the electrical outlet.
67 Comments
royzenm 8 months ago
gister27 3 years ago
I put bleach, vinegar, and baking soda in that tube and let it sit there for about a day. While it did work somewhat, the mineral deposits are still there. Any suggestions?
framistan 3 years ago
Also would you happen to know if I were to stick a pipe cleaner down the heating meal tube (shaped like a horse shoe), if it will go all the way through... I would assume yes.
But so far I've only been able to stick my pipe cleaner half way on one side and then like a quarter of the way on the other side... I would assume both sides are the same. But I guess I can't be for sure, unless I call the manufacture maybe...
RichF3 2 years ago
Juliesteph444 2 years ago
Fortunately, I didn't have the security screws. I did have a "wire" clamp securing the tube over the steel intake valve that was a bit of s PITA to remove, but using a flat-head screwdriver to push it off (from over the steel housing), it only took a few minutes. I thought, yay! I can just wiggle the tube off! Nope! The gals in the audience will appreciate this. I didn’t want to use something sharp that would result in me cutting the tubing (that sucker wasn’t moving!), so I used a steel cuticle pusher (because it had the same shape) to wiggle the tube off of the steel housing so I could get at the gadget that needed to be cleaned.
It actually wasn’t all that gunked up; the issue seemed to be that the gadget had migrated down a bit too far and was too close to where the tube bended in order to marry the steel tube, so after I cleaned it up, I pushed it up a bit further in the tube so the little ball/gadget was further away from the hose bend. Longer story short, these instructions ROCKED, and kept me from tossing something into a landfill. For true, it took me longer to write this than it did to fix my mini coffee maker. Thank you for the instructions and pictures : ) Now I'm just doing a standard vinegar cleanse and it's working GREAT!
cynmb 3 years ago
mortgage7900 4 years ago
Kerry Petruzello 4 years ago
lilkittenspit 4 years ago
Thank you so much for this tutorial you posted
framistan 4 years ago
leanonjesus 4 years ago
Itrytofixthethings 4 years ago
While I lived there, I had cheap coffee pots and they would get absolutely clogged with mineral deposits INSIDE THE HEATING ELEMENT. The result is that NO WATER could get through the pipe. You can visually see it if you remove the plastic pipe off of the heating element. (Always unplug power first!!). Just look inside the pipe and if it looks clogged, it is ruined. The cure for this was NOBODY buys expensive coffee pots. They buy cheapy ones and just purchase another one when it gets clogged. Other than that.... simply make sure the water can flow through EVERY tube and spout. If it heats up, then it must be clogged somewhere.
