Repair a Window Screen on the Cheap
Intro: Repair a Window Screen on the Cheap
In your home or apartment, you may have a window whose screen has a small hole in it. Here's a very quick and cheap way to prevent the bugs and tiny critters from gaining entry!
STEP 1: Cut Some Transparent Tape
As a disclaimer, I've only done this with very small holes in a window screen. I'm not sure if it would work well for holes greater than 1"x1". That being said, gather your supplies:
Place one piece of tape over the hole in the screen and press firmly. Depending on whether the screening material is metal or fiberglass, the tape won't stick very well, but that's okay! We're not done yet.
Flip over the screen and apply the second piece of tape to the opposite side. Now press the two adhesive faces against each other at the location of the hole.
Pardon my craptastic GiMP illustration: the black lines representthe screen with a hole in it (the gap) and the blue lines represent the two pieces of tape "meeting" at the site of the hole.
The tape doesn't have to stick to the screen, just to itself.
- transparent tape (scotch tape or packing tape) whose width is at least as wide as the hole
- window screen removed from window for easy access
- scissors
STEP 2: Bask in Your Success
Your screen is now repaired! It may not be pretty, but it's functional, and super-easy.
6 Comments
RyanPotter 15 years ago
Kozz 15 years ago
Dave Kruschke 11 years ago
gregr 14 years ago
Moreover, if gregr cuts out a little rectangle of screen, gregr will notice that the border strands of this little screen patch can easily separate from this little rectangle. This is why the people of times past used an overlapping, but less attractive rectangle to give the stitching a more reliable grip.
I have used superglue and it has many limitations. I can't imagine how super glue would succeed in holding gregr's "perfect rectangle" in place. However, I could imagine that one minute epoxy or five minute epoxy might make gregr's suggestion repair doable and effective...
Scott_Tx 15 years ago
