Repair Broken Hinges of a Laptop Screen.
Intro: Repair Broken Hinges of a Laptop Screen.
Dissasemble the laptop. Locate the broken insert for the metal bushing which holds the hinge and remove it. Drill a small hole in the center of the cracked plastic insert.
STEP 1: Metal Bushings
This is the metal bushing which is placed into insert on the plastic case of the laptop. It is almost impossible to glue it, because some laptop manufacturers use special plastic for the laptop case, a plastic which does not stick with most glues, also there are a lot of tension in the place where the insert is located and after several times you close and open the laptop lid, the hinge base will crack again. Notice that this little thingy have thread from end to end.
STEP 2: Drill Holes and Refit Bushings
Put the metal bushing back to its place and screw it with a small nut from the bottom side of the laptop. I recommend using appropriate washer because if the nut have small head it might go right trough the hole.
22 Comments
Tuong-HuyN 9 years ago
Good idea.
My laptop (Lenovo E320) happened to have the same problem (broken plastic support for the metal bushings) and thanks to this tutorial I fixed it.
Not doing exactly what was said, since it depends a lot of the specs of the laptop but it gave me the overall picture.
abhiram7696 9 years ago
i have a similar problem. neglecting a lost screw my plastic support for the hinge broke due to regular tension on it. did you use any glue like araldite or something.also where exactly did you drill the hole since my bushing's insert has to have a hole right next to the keyboard is that advisable.BTW my plastic peice completely broke and came off thats why i ask if you used any glue
Some of the plastic pieces around the metal bushings were also broken, I did not use any glue to try to repair it.
What you really need are only the metal bushings (and not the plastic casings around) because it creates the necessary "spacing" from the bottom of your laptop.
As for where to drill, just drill at the bottom of where there are the bushings. For your keyboard, in my opinion there is no risk whatsoever, you only drill through the plastic at bottom of your laptop... But I can't say because I'm not looking at your laptop.
RajeshS155 6 years ago
Now i have connected everything again but the laptop is not turning on and making three beeps
Can anyone tell me what does this mean
sup3rcharged 6 years ago
The beeps are infact error codes. Every laptop manufacturer have their own beep codes so you should obtain document with error codes that are specific only for your laptop. The beep codes are used to locate faults in the laptop assembly, for example: one beep means faulty RAM, two beeps means broken CPU and so on. Sometimes these error beeps are false positive caused by loosy connector and something that is not connected at all, and as you probably noticed there are many of them. At first time you should check that every connector is well seated and that all pins are intact(the lcd display connector have at least 50-100 pins, and sometimes when you use excessive force to connect it, some pins bend and do not connect properly which causes those beeps.)
Good luck fixing your laptop. :)
Sup3rCharged
abdul_111 9 years ago
I have a Toshiba satellite 1660 148 & one side of my screen the hinge is broken and some metal thing sticks out anyone know how to fix that?
CGC1 6 years ago
MelindaC16 7 years ago
We actually found that, if you loosen the nut on the end of the hinge a half turn every now and then, it won't tighten up. Also, for the folks wondering which adhesive to use, please don't screw a hole in your case. JB Weld Clearweld epoxy works great. Just follow package instructions and DON'T get it on the screen.
Also, you can order new hinges from china for $16. 10 days shipping or so. Don't for get to loosen that nut.
CGC1 6 years ago
Turrey1234 7 years ago
JunW8 7 years ago
Is it a typo? "if the nut have small heat (head)" ?
sup3rcharged 7 years ago
Head... sorry. :)
SumonaR1 7 years ago
Source : https://techyuga.com/laptop-hinge-repair/
This is a good hp laptop hinge repair trick. By the way if anyone in Kolkata facing the same issue can check these guys out they are brilliant regarding laptop issues https://techyuga.com/kolkata/
RicardoS123 7 years ago
my bushings were on the upper side of my case which meant i would have had to drill a hole at the top close to where the keyboard is situated. However the concept is good, if you can't drill a hole like me, get some plastic weld (i recommend the highest psi you could cheaply get mine was 3500PSI). Fasten the bushing down ensuring that the plastic weld forms a cylindrical type casing around it. Test with a screw once it dries to ensure it'll hold in place. If the bushing starts spinning as you screw then remove it and weld it over again. 4 of mines broke and this did a great job, took about an hour to do. (DON'T LET WELD GET INTO THE BUSHING HOLE)
RajuK8 7 years ago
very nice information about laptop...and more visit:
http://gfix.in/laptop-service-center-in-hyderabad/
RajuK8 8 years ago
nice post and site, good work! This article is well written and quite informative. More articles should be written and you have just found a follower.and more visit
JenniferA46 8 years ago
I'm a fan of anything I can do myself. Drilling the holes in my laptop makes me nervous but it does seem like a laptop repair I can do on my own. As long as I'm not relying on duct tape my laptop should live a bit longer.
http://www.cxeonline.com
