Repairing Basic Computer Hard Ware Problem (system Disk Failure and Broken PSU and Missing/corrupt Files)
Intro: Repairing Basic Computer Hard Ware Problem (system Disk Failure and Broken PSU and Missing/corrupt Files)
THIS GUIDE IS NOT YET FINISHED, I WILL ADD MORE INFORMATION WHEN I GET A CHANCE.
If you need any help with fixing a computer or if you have any questions at all feel free to message me"
In this instructable i will tell you how to repair basic computer hard ware and software problems.
I will tell you how to:
1.Hard drive problems
2.replacing hard drives
3.Power supply problems
4.System problems (windows XP etc...)
5.Mother Board problems
6.CPU problems
7.RAM problems
8.Speed upgrades
THIS INSTRUCTABLE WILL BE CHANGED DAILY AND NEW STUFF WILL BE ADDED IN SO KEEP CHECKING.
6.CPU problems
7.RAM problems
8.Speed upgrades
STEP 1: Power Supply!
If you plug in your computer and hit the power button and nothing at all happens (no fans or lights come on) CHECK THE FUSE IN THE PLUG.
Only open a computer up if you Know the fuse in the plug is working.
Power supply problems:
1.The light or fan on the power supply do not work.
2.Nothing in the computer works.(plug something into the USB power to see if there is power going to it)
3.No lights / fans or beeps come from the computer.
If any of the above happen to you try changing the power supply unit.This can be down by removing the computer case and removing the PSU(picture below. The PSU is only held by a few screws.
Put a new power supply unit in and try that and the computer should work.
STEP 2: System Disk Failure
If you turn your computer on and it says SYSTEM DISK FAILURE , PLEASE INSERT SYSTEM DISK AND PRESS ANY KEY, this means there is a problem with your hard drive.
FIRST check their is no floppy disk or cd/dvd disk in any drive.
Then restart the computer.
If the above paragraph did not work read below.
To fix this problem you can try to reinstall your operating system first.You can do this by inserting your windows XP/vista disk etc.. and then restart the computer. If the disk loads follow the on screen instructions and if this does not work read below.
If you have added any new hard ware into your computer that uses the same PSU as your hard drive it may be getting less power which will cause it to fail. If you added a new dvd / cd drive remove the power plug from it and try restarting the computer and if the hard drive loads the problem was the hard drive needed more power.
If you still want to use the new hard ware you could buy a new PSU that has more power output. this will give the new hard ware the power it needs and it will also give the hard drive the power it needs.
STEP 3: File Missing or Corrupt
If you get a black screen that says A FILE IS MISSING OR CORRUPT, this can be fixed very easily. Just insert the widows xp/vista disk you got with your computer and then the computer will automatically reinstall the missing file.
STEP 4: System Disk Failure (new Hard Drive Needed)
If you alreasy tried step 2 and your computer still says SYSTEM DISK FAILURE, then you most likley need a new hard drive.
WARNING !! REPLACING A HARD DISK WILL BE LIKE HAVING A NEW COMPUTER, ALL THE INFORMATION THAT WAS ON THE COMPUTER WILL BE ON THE OLD HARD DRIVE AND NOT THE NEW ONE.!!
Replacing a hard drive is simple. first open your computer and look below the dvd and cd drives for the hard drive.(picture below)
Now take the cables from the back of the hard drive. and check to see if it is an IDE or SATA hard drive.
The hard drives in the picture below are SATA , the SATA cable is the red cable connecting to the hard drive from the mother board.
An IDE cable is the ones connecting the DVD/CD drive to the mother board. these can be used on hard drives too so check before you buy a new hard drive.
remember
SATA: small cablecorrupt
IDE: Thick cable with about 24 pins on each end (the ends are long rectangles)
After removing the hard dive bring it to a computer shop and ask them for another hard drive the same or the hard drive you want.
You can buy a 80GB 7200RPM Maxtor hard drive for £30.
To fit the hard drive insert it into the pace below the disk drives and secure it with 4 screws and then put the IDE or SATA cables into it. then insert the power cable.
Turn on the computer and reinstall your operating system by using the disk you got with your computer.
Now your computer is fine .
P.S you may need to download drivers for your sound cards etc.
remember
31 Comments
kj.vergara.7 9 years ago
hi ,, ahm , ,can u teach me all the parts of the system unit on how to fix all the problems . . if you can, teach me how please , because i want to learn a lot about computer hardware . .
Victor805 10 years ago
I remembered I had a very complete error flowchart, it might be useful:
I don't know if it's too much outdated, I guess most of the problems will still apply, sorry if it's a bit blurry, I think the uploader compresses the image.
infraredman21 15 years ago
memyselfand1 14 years ago
twitch2009 15 years ago
dean-101 15 years ago
Derin 15 years ago
Derin 15 years ago
ReCreate 14 years ago
Derin 15 years ago
Derin 15 years ago
Derin 15 years ago
Derin 14 years ago
cavemaneca 15 years ago
