Replacement Car Key
Intro: Replacement Car Key
My car key broke…I’ll just make a new one…and save some money!
STEP 1: Cutting Your Shapes
Trace out your key on the wood.
carefully cut out your shapes. Use a coping saw.
Drill a hole in the internal shape, take apart the saw blade and put it together inside the shape so you can cut it out.
Use sand paper to finish the holes…you want all parts to stay on place with a bit of pressure.
STEP 2: Epoxy
Place the key portion in place and epoxy. Use masking tape to hold the epoxy in place as it dries.
Place the remote part in after the epoxy is dry, you want to be able to remove it to replace the battery.
Finish sanding, then mask off the key part and use clear spray paint to finish the wood parts.
You are done, you now have a great, unique car key!
8 Comments
lkvanz 1 year ago
kyserrolls 1 year ago
Ronna Farley 1 year ago
strigoix51 1 year ago
