Resonator: How to Make a Pipe Out of Parts From Radio Shack.
Intro: Resonator: How to Make a Pipe Out of Parts From Radio Shack.
This is a small pipe, pocket sized for travel. it doesn't look like anything conspicuous, and it works beautifully. i came up with this while working there. I hate that store..... Pick up the Phone Jack and butane blow torch tip you see in the pictures.
STEP 1: Prepwork
Start by unscrewing the top cap from the top of the phono jack.
STEP 2: Hollowing
With you leatherman (or some other insignificant pair of pliers), squeeze the brass tube flat right where my fingers are in the picture. this will separate the two halves fairly easily. Discard the chewed up Brass half, we dont need that. you will be left with a spring, a cap and a tube.
STEP 3: The Spring
Now take the spring out of the inside of the tube. Take a hold of your butane tip and twist it into the small end of the spring. this becomes the guts of the pipe. place this into the tube, wide side first.
STEP 4: The Screen
If you use pipes often, you probably use screens. you can get these at your favorite smoke shop, home depot in the faucet aerator section or at the dollar store in the form of a strainer or splatter screen. however you get them, you need to form it into the tube with a pencil. make sure it clears the inner threading, or the cap wont go on properly. after that, your pretty much done, pack it and smoke!!!
STEP 5: Maintenance and Safety
Okay, so now you have this incredible pocket pipe. its made of metal, and it can get hotter than a kit-cats paw on a tin roof. to avoid burning yourself, you can either wrap it in one inch electrical tape (which only works for a short time), or you can roll it between your hands with long sweeps. this dissipates the heat evenly across your hands.
To clean it, there a a few ways this can be done. One is to heat it up and scrape it with an open bobby pin. the other (and my fav with any pipe) is to boil it in whole milk. If you are using "Forget-a-lot" smokes, drinking this milk is nasty, but oh so worth it. just remember te dissasemble the whole thing to get it truly clean.
One more thing. The name i gave to this is The Resin-ator, and for good reason. you will see why when you use it, but i bet you can already guess. PLEASE, out of respect to me, the inventor, call it by its proper name. I dont wanna be in a circle one day and hear somebody say, "Hey! Pass the ( Any name other than Resinator)" i will confiscate it and you will lose the privelage.
On that note, enjoy!!!
52 Comments
greymatter21 14 years ago
RESONATOR
it sounds cool}][{
joeliolyijr 16 years ago
pyro13 16 years ago
Vulcanator 14 years ago
not all types of smoking is harmful to ur health
cdawg14 15 years ago
is this what i think? Sticky Icky? M.J? Buddha? GANJA?
i hope so...:D
littlebastard 14 years ago
AussieJake44 15 years ago
Jonny Katana 15 years ago
HAL 9000 15 years ago
drinking a tea or chewing leaves sublingually is supposed to be a better way of taking it, as it lasts much longer and will supposedly give you some long lasting "feel good" feelings depending on the dose. it can also cause halluciantions, but will not be as harsh as smoking it. this is what the south american shamans did for a long, long time. i havent heard a lot about this method though, if anyone can confirm or deny i would like to hear some feedback.
i've never done either, but i would like to start growing it for the latter
TheInventor 15 years ago
oilpaint2 15 years ago
Brad1191 15 years ago
BOT Micheal 15 years ago
joeliolyijr 15 years ago
iKill 15 years ago
Alex McCown 15 years ago
explosivemaker 16 years ago
