Retreading Your Lawn Mower Tires
Intro: Retreading Your Lawn Mower Tires
With proper care and maintenance, a good lawn mower can last for decades. This means your machine will long outlast the tread on your tires, making your once self-propelled mower a push mower and making your job much harder. Here's a simple trick to retread your mower tires and keep your mower running like new. All you need is some basic tools and a used bicycle tire, which you can probably get from a local bike shop for free.
You can do the same thing with any solid tires.
Materials:
Used bike tire
String
1/2" long Screws
Tools:
Screwdriver
Scissors or snips
STEP 1: Prop Up the Mower and Measure the Tire
This whole thing is much easier with the rear tires off the ground, so prop up your mower. I used a stool.
You'll need to measure your tire. No need to get technical here. The easiest way is to wrap a string around the tire and then either cut it off or hold your thumb at the length once it is all the way around.
STEP 2: Cut the Bicycle Tire
First, cut the tire to the length of the string. Then cut the sides off so the bicycle tread is the same width as your mower tire.
STEP 3: Screw the Bicycle Tread on to the Mower Tire
Put two screws into the end of the tread to start. Then wrap the tread around the tire, putting in a few screws as you go to hold it tight. Once you get to the other end, trim any extra and add two more screws. I ended up with seven screws total: two on each end and three spaced out around the tire.
STEP 4: Repeat for Second Tire and Get Mowing
Once both tires are retreaded you'll be amazed at how much better your mower pulls. If you live on a mountain, this is going to be very important. Of course, the next step is to find a gullible neighbor child who wants money more than free time and will mow your lawn for you.
35 Comments
Nicolaslawn 3 years ago
38super 4 years ago
cpams322 6 years ago
came with rubber tires but now all they make is plastic tread tires for
it which wear out in 1 season (both OEM and aftermarket, they are all
plastic treads for my model). So I did this retread instead because rubber grips the
turf SO MUCH BETTER THAN PLASTIC TREAD. I have a bank to mow and a good
grip (which only rubber tread provides) is essential! If this
retread method cost me $100, I would still do it because it would keep
me safe on the bank and would work so much better. And if mounted to
the tire well enough it should last a long time and would save money in
the long run. So far it's been 2 seasons and still holding up well for me. But I used DAP Flexible CLEAR Sealant as a glue as well as screws and I also used the sealant to caulk around the edges of the tread to keep dirt out.
theskashow 6 years ago
I have found that a little bit of glue is a great addition to this retread.
Dickerson888 6 years ago
My mower is front drive and I was worried the screws wouldn't be enough so I used contact cement and screws. I was concerned when sideways pressure was applied the tread would slip off. Mowed today with it and worked fine.
Lee Wilkerson 8 years ago
Great idea for larger tires, but 3 inch to 5 inch tires usually don't cost that much. Besides, extra rubber meeting any surface means extra friction as rolling resistance. There is already far too much rolling resistance in small tires.
honda_on_nos 9 years ago
DavidR166 8 years ago
bigpig 9 years ago
Unnecessary comment.
tfellad 9 years ago
tfellad 9 years ago
Great idea
JohnC20 9 years ago
Used mountain bike tires for my grandkids PowerWheel Car so he could ride in the yard and not the street.(too fast for street) was fun to do. The Dad sold it in garage sale last summer. Car was 4 years old when it sold. Love the DIY Re-Tread
espdp2 9 years ago
Hardwood75 beat me to it. Powerwheels are *begging* for this treatment, as is my front wheel powered mower. Thanks!
Bverysharp 9 years ago
A great use for old bicycle tires, and a neat solution to a vexing problem! Well done!
jakall3 9 years ago
hdmotorc 9 years ago
Hardwood75 9 years ago
Great idea! I'm going to use this on my kids powerwheels too.
pietro.busatta.7 9 years ago
brilliant!!
zap1998 9 years ago
Awesome idea.
