Retrieve Data From a Dead Computer
Intro: Retrieve Data From a Dead Computer
This involves removing the hard drive from the dead machine and making it appear to be an external HDD on another computer.
You will need:
A second computer
An external HDD
Note: The external HDD must be of the same type as the target HDD.
You will need:
A second computer
An external HDD
STEP 1: Disassembly
The name says it all.
I am using a 60GB iomega portable usb powered HDD. this is good because it uses a Laptop HDD and i want to get files from a laptop. I you are trying to get file off a PC then you will need a different external disk.
Once you have removed the dick from its enclosure gently disconnect the PCB. This is the bit that controls the drive and connects to a usb port..
STEP 2: Disassembly 2
Open the target computer and remove the hard drive.
STEP 3: Conect Up
Very simple.
Plug the PCB into the new drive. Be careful not to bent any of the pins of flex the board too much, it was never designed for this kind of abuse.
STEP 4: It Works!
Or not.
Plug it into a computer via usb and it should appear as a removable storage device.
For desk top drives (SATA ?) You may be able to connect it to a spare port in you machine but i haven't tried this.
Please leave comments and criticisms.
Good Luck!
Good Luck!
20 Comments
bripab009 8 years ago
I found this tutorial quite useful and helped me recovered a lot of deleted files from my computer hard drive. Here is the step by step guide:
http://www.imoresoft.com/data-recovery.html
tonyo2 9 years ago
Loved this blog post will try & experiment in case of my
raid 5 recovery, if need arises like
in emergency or so.
http://www.easydatarecovery.ie/raid-recovery-2/raid-5-recovery/
panchavanparivendhan 12 years ago
hornbadoing 12 years ago
jaketeater 13 years ago
Anyway, this guide has a few different recover methods that use Live CDs.
The Hard Drive Recovery Guide for Non-Geeks
All of the methods are in plain language.
HBU 13 years ago
ryzzey 14 years ago
You might want to check this sentence!!!
Guard13007 14 years ago
SmAsH! 14 years ago
metal-matt 14 years ago
XOIIO 14 years ago
infernisdiem 14 years ago
matstermind 14 years ago
diyhopeful 14 years ago
techman9 14 years ago
Tungston 14 years ago
webman3802 15 years ago
fungus amungus 15 years ago
Joe Martin 15 years ago
