Reuse a "disposable" Spice Mill
Intro: Reuse a "disposable" Spice Mill
I've developed a taste for fresh ground pepper, but as someone on a low salary I don't want to buy an expensive pepper mill. Some spice companies sell peppercorns, sea salt grains, and dried spices etc. in neat little grinders, but you're not supposed to be able to refill them, which is a bit silly since you can buy bulk spices much cheaper from most supermarkets.
STEP 1: Oops
My first attempt at getting the plastic grinder top off the glass container went badly. I tried to use a spoon to pry it off, wedging the end of the spoon into the lid and banging it on the table. It made some cracking noises, which I thought was glue. It turned out that I'd broken the rim of the glass bottle off.
STEP 2: Soften the Plastic
Later when I had another empty pepper grinder, I decided to soften the plastic before prying it off more gently. I set my oven at 250F and put the grinder inside for about 10 minutes.
The room smelt like pepper =)
STEP 3: Remove Lid and Refill
Pry off the top gently. REMEMBER: hot glass doesn't look hot!. Use a potholder.
Refill with peppercorns or whatever other spice you like. I don't know if maybe some others might be too hard for the plastic grinding surfaces to handle. You may have to experiment. Also, if you look at the size of the teeth (on the underside of the top) it can't handle very big objects.
STEP 4: Replace the Top
Bang it lightly with your fist until it clicks. Enjoy fresh ground pepper.
112 Comments
mrbreezeet1 3 years ago
Any idea why?
richfiles 6 years ago
All it took was some hot water from the sink... Granted, my apartment has some HOT water, but all it took was just a few seconds of heating, once the water was at full hotness.
ignisgeodacius 3 years ago
LiftAndLove 11 years ago
xenobiologista 11 years ago
mesagoat 7 years ago
"totally depends on which part of the world you live in, which shop you buy your groceries at, and which brand you're looking at."
mos' o the "grocery" stores in the food deserts of this DisUnited States, are little more than repositories of toxic junk. something healthy, and non-gluten, like rice flour is beyond the scope of human comprehension for some of this store managers. blessing's to the food hackers, diyers and healthy thinkers out there.
mattcintosh 8 years ago
my problem is the grinders with the peppercorns are actually *cheaper* than just the peppercorns in a bottle. The weights were almost identical, but the grinder was about 50 cents less... go figure...
SueM126 7 years ago
I love the peppercorn medley but don't like that the bottle isn't refillable. It's wasteful to keep throwing thing in the landfill or recycle bins. I went on a Google search to find that this mix isn't exclusive to this brand, However, like you, I found the price of the item in bulk is more expensive. I love that this grinder has 3 settings and is easy to use, so I wrote the company asking them to change their ways.
Blissterful 3 years ago
xenobiologista 8 years ago
At the time and place when I wrote this, this was the most economical option for me to get fresh ground pepper, and it seems to have been useful for a few other people too. If it doesn't work for you, feel free to ignore this.
Its like they were punishing you for actually buying a real peppermill.
ThatC 8 years ago
Great tips here! I heated grinder container in microwave for about a minute, then held container in left hand using pot holder, then using my right hand, pried lid off with the tip of potato peeler as suggested below. No trip to Trader Joe's, no buying anything, just a minute (literally, no more than one minute) and the container to re-use!
marcus368 3 years ago
900w microwave at 45 seconds, held container using towel, slight pull twist to lid and came straight off and in perfect condition
Jo-AnnS4 4 years ago
WilliamS496 5 years ago
