Reviving Old Furniture
Intro: Reviving Old Furniture
Sandpaper in assorted grits ( for this project I used 40 and 80 grit)
Sander ( electric or hand but electric is far easier)
Stain ( in your choice of color)
Polyeurethane ( you can use a polyeurethane and stain mix and still get great results)
Paint brushes
Rags
Rubber gloves
Dust mask
The difference betwwen the beginning finish and the end result makes this all worth it.
STEP 1: Removing the Old Paint/varnish
STEP 2: Staining the Wood
After every thing is well sanded and free of flaws you can start to stain your project. First make sure the stain is thoroughly mixed so you get an even color. Apply the stain by brush or rag and let sit for about 15 minutes. When 15 minutes has gone by you will need to remove the excess stain with a clean rag. At this point you can either go straight to the polyeurethane or youcan continue to stain ( the more coats of stain you use the Deeper and darker the coloring) Just remember to remove the excess stain before going to polyeurethane.
6 Comments
siamonsez 12 years ago
Entropy247 12 years ago
pfred2 12 years ago
Minwax and Varathane are good choices for paint finishes. I probably have Minwax's whole line of oil stains kicking around now. Well, maybe not that bad but easily dozens of quarts. Mostly I use their natural on things I make. Often I have to match pieces though then I need a lot of different colors.
pfred2 12 years ago
Once you have your surface stabilized level it. Build up some top finish leveling as you go and thinning your finish material more and more as you reach your final coat. Pro tip: Read the label for what the manufacturer recommends for clean up as an idea of what a good thinning agent might be for the product you are working with. Sometimes they just come right out and tell you what to thin with too but remember they're in the paint selling business so ... it doesn't really pay them to tell you how to stretch their product out.
I think a lot of painting is in the magic of thinning personally. I usually get a glass finish after 3 coats myself. A builder, a leveler, then a final spit polish.
Unless you really dig the fumes stay away from brushing lacquer. Putting lacquer down properly is pretty involved. All other modern finishing products are pretty great within their individual limitations.
pfred2 12 years ago
When I strip furniture I use Zip Strip. Costs a bit but saves me a lot of work. I still have to sand it a little once it is stripped but sanding finish off can be hard.
I'm actually refinishing the top of a mid century modern table right now.
zazenergy 12 years ago
