Robot Arm MK2 Plus (Stepper Motor Used)
Intro: Robot Arm MK2 Plus (Stepper Motor Used)
Overview
STEP 1: Print All 3D Slt File.
https://www.thingiverse.com/thing:2520572
STEP 2: Motor Gear Assembly
STEP 3: Gear Arm Assembly
STEP 4: Main Arm to Base Assembly
STEP 5: 2nd Arm Assembly
STEP 6: 2 Stepper Motors Assembly
STEP 7: Low Base Assembly
STEP 8: Low Base Bearing Assembly
STEP 9: 3rd Stepper Motor Assembly
STEP 10: Low Base Gear Assembly
STEP 11: Electronic Part Asembly. Install Driver & Software
To install driver and software for Arduino pls follow video instruction.
15 Comments
yusuf33 8 months ago
MartinS453 4 years ago
kakaivy 2 years ago
charliecat2015 2 years ago
Stewmaker89 2 years ago
Will build it as soon as possible
sainath352 2 years ago
any suggetions
CoilMonkey3D 3 years ago
renanrojash 4 years ago
gracias por la ayuda
jawwad lodhi 5 years ago
I have printed this design and i am using NEMA 17 stepper motors it fits perfectly with holes in the design but the only thing is that the shaft is a bit longer of my motor so have to cut it down to correct length .
Devekr 5 years ago
What size are the bearings?
MohsenMouemen 6 years ago
gamba56 6 years ago
I want to make your robot arm design but missing the base stl file. Look forward to make when available :).
myrobokits 6 years ago
Grt what is the model of stepper Nema? size
trieutuan_vnu 6 years ago
You can use stepper 42HS40
DIY Hacks and How Tos 6 years ago
Great modeling job.
