Robot Tools and Materials
13,705
Introduction: Robot Tools and Materials
About: My name is Randy and I am a Community Manager in these here parts. In a previous life I had founded and run the Instructables Design Studio (RIP) @ Autodesk's Pier 9 Technology Center. I'm also the author of…
Step 1:
For the Single Motor Bot lesson, you will need:
(x1) Fly swatter
(x1) 1/4" x 5-1/4" turnbuckle with eye bolts
(x2) 2" caster assembly
(x1) 3" caster assembly
(x2) 3/4" x 4-40 flathead bolts
(x2) 3/4" x 4-40 washers (optional)
(x2) 3/4" x 4-40 nuts
(x1) Assorted zip ties (not pictured)
(x1) Modified continuous rotation servo and 4 x AA battery pack**
(x4) AA batteries (not pictured)
**The modification of the motor is covered in steps 13 through 17 of the Basic Electronics Skills for Robotics lesson.
Step 2:
For the Sponge Bot lesson you will need:
(x1) Modified continuous rotation servo**
(x2) 2 x AA battery pack
(x4) AA battery
(x1) SPST toggle switch
(x2) 12" aluminum rulers
(x1) Swivel ball caster
(x1) Large jar lid
(x1) 2" plastic furniture slide
(x1) Permanent marker
(X1) 1" paintbrush
(x1) 5/16" x 1" bolt
(x1) 5/16" x 2" bolt
(x2) 5/16" nylon insert lock nut
(x6) 5/16" washers
(x1) 5/16" shaft collar
(x1) Sponge
Step 3:
For the Skitter Bot lesson you will need:
(x1) continuous rotation servo modified for direct drive**
(x1) 3 x AA battery holder
(x1) DPDT toggle switch
(x4) scrub brushes
(x1) small plastic container
(x1) ballpoint pen
(x1) 1-1/2" x 3/8" corner brace
(x1) assorted zip ties
Be the First to Share
    • Battery Powered Contest
    • Plywood Challenge
      Plywood Challenge
    • Plastic Contest
      Plastic Contest
