Roommate Blocker 1.0
Intro: Roommate Blocker 1.0
This project should be done at the beginning of the new school year.
The duration of this project is completely dependent on how large of a wall you need.
KEEP IN MIND, you will PROBABLY need to drill at least one hole into your wall. Do what you have to, to avoid making the holes too noticeable. In other words... PREDICT damage that may be seen at the end of the year, hint hint. My wooden frame uses about THREE wall holes.
Why: Your roommate smells. Your roommate is noisy. You have a girlfriend. You don't have a girlfriend. Your 21 and think it's unreasonable that your University does not provide adequate housing... you would understand if you knew what we paid per month.
Everything seen in this guide can be found at lowes/home depot... I'm sure you could also supplement some of the items used for hardware found at local stores.
The wall is also really sturdy, but I think I used the bare minimum in order to accomplish this.
Cost:
Without tools: $120,
With tools: Roughly $50
This project will reduce noise by about 70% and eliminate all light... mostly.
** Also, you should probably get your roommates permission.
*** The entire project took about 5 hours to complete.
**** There was no glue or joint compound used in this project, it is fairly clean and straight forward.
***** If you are concerned that your room may spontaneously combust, this project will probably facilitate the burning process.
*******This project may violate the terms of your dorm agreement, it also may not be approved by governing fire officials. Build at your own risk.
STEP 1: Materials and Tools
Drywall is pretty cheap so you should buy about 1.5 times more than you would think to buy.
Enough Wooden studs to build a frame in the are you want to frame off. (The length of your pieces should match up with the height of your ceiling. You also may want to have one long piece going to the door, so keep that in mind when picking wood. I used 1.5"x1"x9'. I think 96" is a standard ceiling size in college dorm rooms.
1xbox of concrete screws,
1xbox of drywall screws, ($6.23 for a 4'x'8'x1/4")
1 twin bed sheet,
1 sliding door kit ($12.99)
1 unmounted door ($19 at lowes... it's pretty light too)
A roll of velcro tape
Foam tape (cover up drill holes and adds sound insulation. It also helps create a seal)
1 inch Copper tube straddle ( this was just a cheap way to make a handle, you can get whatever you'd like)
1 Twin XL fitted sheet ($9.99 target(tar-zhe) )
Tools:
Drill
Saw
Miter Box ( for a college dorm room this is essential, the room is too small to use clamps in odd places.)
Hammer
Pliers
STEP 2: The Run Down
There are only three major steps to this project:
Build a frame.
Put up the drywall.
Mount the door.
This seems simple, but dorm rooms are never perfectly square, so you will need to adjust because nothing is really straight. This wall obviously does not have to be perfect since it just intended to split a room into two, but the door will slide better if the wall is straighter.
STEP 3: Building a Frame
Drill the guide hole, and mount and drill in the first beam. Drill another hole if you need to, this is the anchor of the wall, everything else will rely on the strength of that connection in order to support the weight of the door. You can drill as many holes as you want... but your going to have to pay for it in the end... I think making perfect measurements and wedging will be fine for supporting the 10-15 pound door.
If you want to have a thicker wall, you need to use a wider beam. I used 1.5", since dorm rooms are small I thought that this would be a pretty reasonable beam size.
Since you will be dealing with a smaller space, it is likely that you won't need that much wood. I covered the entire length of each wall with wood, wedging the opposing side into the 8' space. Cutting the edge of the beam at 45 degree angle will also facilitate the wedging process.
I used a sliding door that is wider than half the width of the wall, so you will need to have the door port off center ( that sounds much more confusing than it is). I also wanted to guarantee that sound and light would be blocked, so i made the door frame in inch shorter on each side and on the top. This would cover up future mistakes as well as assure that the door would cover the hole.
There are many different ways you can build the frame, just make sure there is an area that you can wedge the wood into. Also, remember where you put the beams this will make your job easier. Take a picture if you can not remember.
When you wedge and mount the outer frame, you can start mounting the inner frame. You can design it how you like, but use my blue print as a guideline. I also ran out of wood at one point, so on of my cross beams looks shortened. If you want to put a screw in at an angle, you will need to drill a pilot hole.
The blue print included uses angled cross beams, in order to accomplish this you will need to make two 45 degree cuts that are parallel to each other.
STEP 4: Add Drywall
Turn the drywall on its backside (paper backed side) and outline the wall based on your measurements. I placed a ruler on the surface of the drywall in order to cut a straight line. Take a straight edge and pass through your sketched lines a few times until you feel it cut through. Don't worry of you didn't fully cut through. Carefully lift up the drywall and bend the piece at the cut line, the drywall should break. Now, you can take your straight edge and cut through the cardboard backing. This stuff gets messy, wear a mask and cover the floor, or rent an industrial vacuum.
Once you've got your shapes you will want to mount the drywall onto the studs. With the drywall in place, find your studs and drill away. I used about 8 screws per 4x4 sheet.
Now that both sides are mounted, look for gaps, you can cover them later... but keep note of them.
**Use 1/2" drywall on each side to increase sound blocking. I used 1/4"
STEP 5: Mount the Door
The mount that I bought is intended to be mounted so that the holes are parallel with the floor. I mounted the holes perpendicular to the floor, it worked out better for me. Follow the directions given with the kit, keep the plastic rail guides.
In order for the door to work well the rail needs to be pretty straight. Have a friend help you out. Add the wheels to the door, and slide it onto the tract.
The door may make a little noise, used WD40, it works like a champ and makes sliding work a lot better.
You can also add the door handle at this time.
STEP 6: Sound and Light Proofing
The best way to increase the sound blockage would be to increase the drywall thickness, but that would be a little more expensive.
With the door closed I looked around the wall and used foam tape to cover up any openings. If the door is moving around a lot we will fix this in the next step. The foam works really well and will provide a seal comparable to a quality sliding door. Add the foam when the DOOR IS CLOSED. Use the door as a guideline for laying down the foam.
STEP 7: Decreasing Unwanted Motion and Gaps
The door will also move around perpendicular to the sliding motion. I eliminated this by Velcro taping one of the plastic guide pieces underneath the door... it works very well and will not come off.
There was also a sizable gap between the closed door and the interior drywall. I measured the space (door way) and cut a long piece of drywall to fit into the empty space.
STEP 8: Making It All Look Good
I didn't want to paint anything... it's messy, and will spill everywhere... Don't use paint.
I didn't mind small gaps because I knew that I'd be covering up the wall with some flexible material.
I went to target and bought a twin XL fitted sheet, I didn't want any seem lines so I made sure that the sheet was at least the size of my wall. I cut the sheet to size and stapled away. If you pull tight enough, the wall will look like it's painted.
I used some standard picture frame hooks, and hung some posters... NOW, it looks like a normal college room wall.
97 Comments
dragonvpm 14 years ago
lampajoo 14 years ago
Jayprice0057 9 years ago
The bed and sheets are significantly more flammable than any of the materials listed. And heaven forbid you have a mattress topper.
dragonvpm 9 years ago
This project actually calls for attaching fabric to the wall in order to avoid having to tape, mud, and paint it. So at least some of the materials are as flammable as your examples.
More problematically though is that this is being aimed at dorm rooms where two people are living and the author stubbornly refuses to acknowledge some of the basic issues that both people should be aware of and be able to look at before building this wall. It's honestly a good idea and a great example of what you might do in an apartment or a house, but it could be incredibly dangerous if it's not placed in a safe location. He sarcastically refers to a fear of "spontaneous combustion" as a childish response to the concerns brought up in other comments and that's unfortunate.
As someone who has worked in engineering and construction for quite some time, I can honestly tell you, based on my professional experience, that this sort of project could be dangerous if the people building it don't know that they need to pay attention to things like egress, smoke alarms, sprinkler systems, etc... What's worse, each and every project has it's own considerations and things to look out for and what works well in one project might not work at all in another. The real danger presented by a project like this isn't that it would burst into flames itself (although with fabric on top it could catch fire much more easily than drywall alone would) but that it might block someone's ability to escape in the event of a fire.
Furthermore, if someone builds this in a dorm, there is a decent possibility that they could get in some (possibly major and expensive) trouble because of how dangerous this can be. It might be built in a first floor double where one half has a door and the other has a window and someone could still be expelled because the powers that be at their university became aware of it and judged that it was a safety issue because it blocked a smoke alarm or fire sprinklers. Dorms (and universities in general) are becoming stricter and stricter when it comes to fire & life safety, and ADA issues (often as a result of accidents or problems) and it wouldn't be all that hard to imagine that what someone might have built 5+ years ago might be less and less feasible as time goes on. Heck, now, I would also caution about how this might impact a person with disabilities being able to access the walled off portion of a room.
Ultimately dorm rooms are a strange creature that we all tend to treat as our own private, inviolate spaces but they're part of a University system that has to treat them as a something like an office building that meets a whole slew of safety and access regulations. From a "getting in trouble w/o having a fire" perspective this project might work great in an apartment with a lenient landlord or in a house with parents/family, but not paying attention to the safety issues inherent in it make it very possible that this project could be a significant danger and I wish the author had been willing to think about those issues and incorporate them into his Instructable.
Romado12187 9 years ago
Here is an itemized list of items that are more dangerous, and more commonly found in a dorm room:
1. Candles.
2. Irons.
3. Hair Irons.
4. Bongs, and other smoking paraphernalia.
5. 8 week old Chinese food.
This wall can be broken down with a strong push, it's designed to stop annoying noises such as:
1. A roomate flogging his girlfriend.
2. A roommate listening to Jarule at 3 am.
3. A roommate typing on his computer until the early morning.
4. A roommate using his hand instead of his girlfriend.
5. A roommate who snores.
Violating Building Code: $1,000
Violating Fire Marshall Code: $1,500
Finding a post you commented on 5 years ago and spending 15 minutes writing an overly aggressive comment: Priceless.
Why this is so hard for you to understand? Unless you're a hoarder, EVERY single item that you mention will not obstruct your ability to get out of a room in the event of a fire or other emergency. A candle won't prevent you from hearing a smoke alarm (thereby making it possible that someone might sleep through enough of a fire to die of smoke inhalation) and various roommate related noises can't keep fire sprinklers from reaching a size-able portion of a room (which most new dorms have in every single occupied room). You're effectively turning one room into two and a large number of fire and life safety components are allocated on a room by room basis so this can be a problem if you leave each half of the room without all the protections it's supposed to have.
You make the observation that the wall can be broken down with a strong push, but you also mention putting in some screws and wedging the wall in place. What if someone wedges it in place such that they can push it out from one direction and not the other? What if the fabric covering the wall is on fire? What if your roommate put something big and heavy against the wall so you can't push it down? Or what if someone smaller and weaker than you is in that other space and just doesn't have the strength to push it down? I think you're right, that wall will stop all those things that you intended it to do and that's excellent. I could easily see thinking about building something like that in an apartment (especially one where a landlord was understanding or just didn't care) like a one bedroom or studio situation where a couple could be sleeping on one side of the partition and keeping TVs/computers/etc... on the other At no point have I ever thought that your idea was bad, but there are several big and small legal and safety issues that come into play especially if it's used in a dorm room.
Your misuse of the tired old credit card trope implies that I just happened to randomly decide to comment here again. Apparently, you don't understand how comments work because I was replying to a comment that I received on this Instructable recently. Instructables has a neat option where I can click a box and my email magically notifies me when someone responds to a comment I made. I happened to receive one of those notifications a few days ago, I mulled it over for a bit and decided to chime in again. In the intervening 5 years I've actually had occasion to inspect houses that have had fires and talk to fire fighters who dealt with those fires and I'm not joking about the potential danger that an Instructable like this can pose to someone who isn't an engineer or somehow involved in construction or building (which could easily include a couple of 18 year old college kids). No it's not dangerous to everyone and most likely no one who actually bothers to build this will ever have a problem, but it can be a danger and it can cause someone a good bit of grief if they build it without being aware of some of the possible, non-trivial problems they could run into.
If my previous comment was overly aggressive and hurt your feelings then I apologize, but most of your comments to this Instructable have been overly defensive and I don't understand why or why the best you can do to respond within the Instructable is a single snide comment about spontaneous combustion. I've never once said that this is a badly written or even bad Instructable. I think it can be very useful for someone who needs/wants to accomplish this with a room, but especially since it's aimed at people in dorms I think it's unfortunate that you've dug in your heels to such a degree that even now, 5 years later, you spend 15 minutes coming up with a stupid list of things that do NOT compare to building a wall in your room (unless you eat a truly epic amount of Chinese food).
Romado12187 14 years ago
However, you're right it is a matter of looking at pros and cons and if the Instructable was aimed at just you putting it up in your house, I'd tend to be less concerned about fire safety issues, but you're specifically aiming this at people living in doubles in dorms and I thought it was something worth mentioning so that both people living in a room could consider if this was the sort of thing they might want to build.
I can respect that as a builder/engineer yourself you can feel that the pros outweigh the cons, but something like this could be built by someone with less skill or expertise and it might be worth discussing how they could go about selecting a location for the wall that is as safe as possible while still being useful as a room divider. Or, it might be worth noting ways in which they could make this project safer. Things like making sure that there is a smoke detector on either side of the partition and possibly installing a battery powered one (they're ridiculously cheap) on one side if necessary, perhaps having a fire extinguisher in the side of the room without an exit, etc... etc...
While it is true that everything in a room can be a fire hazard, this partition could conceivably be a major enough fire hazard and obstruction that IMO it's worth looking at the safety issues more closely than you might look at how dangerous your books and class notes might be. Plus consider that in a dorm setting there could be liability issues for students and parents (beyond the safety issues) should a fire ever happen.
flamesbane 14 years ago
If he is going to violate building codes he should at least make that much clear in his instructables because other people WILL do this, and without that knowledge they could find themselves in a mess with both their university and city codes council/fire marshal.
Laws and rules are different everywhere. Putting in legal warnings would be a huge waste of time.
Furthermore, if depending on the university someone doing this could result in expulsion, or in the least a fine.
A simple "check the laws in your area, and the rules of your university before attempting" would be ample warning. Most instructables that feature a dangerous or potentially illegal activity have a warning like this.
In addition, this instructable is about putting a wall into a dorm room. Period. This is clearly stated in the instructable, and there are many mentions of not "drilling too many holes". It is not about dividing a "little room" but a dorm room, the whole tone of the instructable is based around this, saying that this is not relevant is simply ignoring the facts.
Wesley1 14 years ago
crickle321 14 years ago
JoelDude 14 years ago
