Rotary Tool Oscillating Attachment
3,236
42
6
Introduction: Rotary Tool Oscillating Attachment
About: Ews & qualified welder/metalworker since 1998
I had cheap oscillating tool.
I bought it years ago, after couple weeks of use it broke. It cost 10 dollars, so i didn't bother to return it.
It waited long time in my closet, until one day i decided to fix it.
Motor was burnt so badly that i rather started to think another way to use it.
Step 1: Lets Start.
I removed the casing, and cut the motor out with angle grinder. I left it about 12mm long.
I "machined" the axle with angle grinder and flap disks to 8mm diameter.
It was easier than i tought, because axle was surfaced with thick layer of varnish, and after removing it, i had to remove only half millimeter from the diameter to get it to desired size.
Then i did M8 thread to it.
Step 2: Collet..
Whole idea was so simple.
I inserted dremel collet to the axle. (that silvery one wich connects flex shaft to rotary tool)
Because dremel uses weird threads in their tools. I had no suitable tools to make similar threads.
I used M8 its nearly same sized.
I did M8 threads for the collet too. It mixed the thread, but it seem to fit firmly. Secured it with stong epoxy.
that should last.
And to the idea..
I use same silver collet in my dremel too, regular nail works as an axle between them.
I didn't secure nail any way in case that i need to change it.
Step 3: Casing..
Casing could have been done with 3d printer too.
But i wanted to go with hack style all the way.
Dremel cutting guide attachment worked nicely in that purpose.
It fitted little tightly, but i tought thats just a good thing.
I applied glue between the casing and oscillating head.
Finally secured it with small screws using the holes in the oscillating head.
I have used it a lot, without problems.
Step 4: Ready..
Ready to go.
I have used it a lot, and without problems.
If some brand starts to make these, i would buy one.
Of course it needed to be painted black, so it fits with my other attachments. .)
Glue Challenge 2016
Glue Challenge 2016
Be the First to Share
    • Plastic Contest
      Plastic Contest
    • The 1000th Contest
      The 1000th Contest
    • Battery Powered Contest
    6 Discussions
    Great idea! Is it Sturdy or a little shaky and wobbly?
    The other Finnish guy
    Reply 3 years ago
    Its sturdy. It could be wobbly if used example for cutting high speed and held with one hand from the back end. But with sanding it in one hand its sturdy. When cutting, its more natural to use both hands anyway. Little development for the casing, and it would be very good product. ( i think )
    Reply 3 years ago
    ..sanding with one hand. ( is it possible to edit comments? I haven't found that option)
    JörgenBörg
    JörgenBörg
    Reply 3 years ago
    nope, you have to make sure your grammar and spelling is correect in the first time...
    JörgenBörg
    JörgenBörg
    Reply 3 years ago
    ...correct
    JörgenBörg
    JörgenBörg
    3 years ago
    Nice to meet you here! great tool mate!
