Rotating Guitar and Ukulele Stand
1,021
20
5
Introduction: Rotating Guitar and Ukulele Stand
About: Currently an engineering student
A place to store your instruments if you have no wall space to hang them.
Step 1: Gather Your Materials
This project is easily customize-able, so you aren't restricted to the materials presented here.
I used:
-Multi material screws
-Metal brackets
-Washers
-Peg and hole board hooks
-Wooden Lazy Susan
-2x4s
-Velcro
-A clipboard
-Command Hooks
-A plastic container
-Spray paint
Tools Needed:
-Saw
-Drill
-Sander (or sand paper)
Step 2: Detach the Wood From the Lazy Susan
Unscrew the metal part from the wooden part of the Lazy Susan
Step 3: Cut the 2x4s in Half
The 2x4s will serve as the legs to the stand
Step 4: Drill the Metal Into the Tops of the 2x4
Either drill the Lazy Susan yourself or look for one with conveniently placed holes around it's circumference.
Position the legs evenly on the Lazy Susan, and drill them together.
Step 5: Brace the Legs
Measure out the height of where you want the bracket to be
Then find the center point of each side of the 2x4
use a level and or T-Square to make a straight line.
Line the bracket ends up with the center mark. Line the top of the bracket with the straight line made with the T-square and or level.
Drill the bracket in using a screw and washer.
Repeat process 4 times. Have two brackets on the inside of the 2x4s and another two brackets on the outside of the 2x4s.
Step 6: Reattach the Wooden Part of the Lazy Susan
Step 7: Attach the Hooks
Choose where to add the hooks for your ukuleles/guitars
Pre-drill the side of the Lazy Susan
Screw in the hooks
Step 8: Spray With DW-40
(Optional Step. Use as needed)
Step 9: Prep and Paint
Prep the area to spray paint
The Spray Paint
(You can chose to sand down the wood to be smoother before spray painting)
Step 10: Attach Velro to Clipboard
Cut out pieces of Velcro and attach them to a light weight white board.
Attach corresponding pieces to the legs of the stand.
Mount the white board on the stand
This serves as a place to hold printed out music.
Step 11: Attach Velcro to a Container
Attach Velcro to the back of a light weight container
Place the corresponding piece to the legs of the stand
Mount the container.
This serves as a place to put your accessories: capos. picks, extra strings, etc.
Step 12: Attach Command Hooks
Attack to the inner part of the legs.
Serves as a place to hang a ukulele bag or extra straps
Step 13: Final Product
Be the First to Share
    • Plywood Challenge
      Plywood Challenge
    • Plastic Contest
      Plastic Contest
    • Battery Powered Contest
    5 Discussions
    Jadem52
    Jadem52
    2 years ago
    Cool project, could you make one for a few pianos?!
    blazemiranda
    blazemiranda
    2 years ago
    Great Instructable Jackie!
    Penolopy Bulnick
    Penolopy Bulnick
    2 years ago
    Great use of space with the lazy susan and storage underneath :)
    JNECreate
    JNECreate
    Reply 2 years ago
    Thank You!
    CarterB18
    CarterB18
    2 years ago
    Absolutely love it!!
