Rough Wire Wrap Rainbow Circle Earrings
Intro: Rough Wire Wrap Rainbow Circle Earrings
I tend to collect jewelry making supplies without a plan ahead of time. I happen to have these fun black circles and some thin aluminum rainbow wire and decided to try a simple and rough wire wrap design with the circles to make rainbow earrings with a criss cross wire look.
Instructable 377
STEP 1: Wrap Rainbow Wires
Start with your first color of wire. You don't have to cut it to start, but lay it out across the circle so it extends 1.5" or 2" over. Now carefully wrap that around the edge. You can use your nylon covered pliers if you need to help flatten or tighten it. I tried to wrap it twice on one side, bring it to the other and wrap it twice more and then end the wrap in the back if I could.
Now, cut the aluminum so it extends the same distance across the other side. Do the same where you wrap twice on one side and twice on the other.
Trim any excess you don't want.
Make sure the ends of the wire are wrapped as close to the circle as possible so they won't catch on anything.
STEP 2: Repeat
Repeat this with all the wires. I recommend not doing them all across the center as they'll all over lap and it will get fat there. Try to do them in a random pattern.
I also tried to weave the wires around so they weren't always just stacking on top of each other.
Try to evenly space them.
STEP 3: Add Findings
Find the spot you want to be the "top" and add the larger jump ring, then the smaller one attached to the earwire.
Repeat with the ther earring. Either make it exactly the same or just do it randomly again.
Have fun with it!
