Rubber Breadboard (Silicone Circuit)
4,303
86
15
Introduction: Rubber Breadboard (Silicone Circuit)
About: I want computers to be wilder. https://www.instagram.com/hikinghack/ https://twitter.com/HikingHack https://www.youtube.com/user/blorgggggg https://github.com/quitmeyer
Get all the functionality of a regular breadboard but in a fun, flexible bouncy form factor!
A full rubber Bread-board is nice because electronics can be pressed into the rubber nicely, and once you have your circuit set, you can adhere the breadboard directly to a silicone sculpture.
Plugging electronics into the rubber has some advantages
A) You can have more unlimited numbers of wires plugged in
B) The rubber grips your wires and holds components in place better (no falling out when shaking the breadboard)!
C) it doesn't fill up with water and corrode when left outside
Plus, with a rubber breadboard you can make the transition from test-circuit to permanent quite easy by just potting the full design in silicone once you get your circuit functioning in the correct manner.
****Note this is a smaller instructable broken out from the full instructable all about Silc Circuits: www.instructables.com/id/Silc-Circuits-High-Perfor...
Step 1: Mix Your Conductive Silicone
The Recipe :
(Contributed to the Public Domain 2015)
Materials
· Platinum Cure Silicone ( Smooth-On Sorta Clear 40 $30) (will also work with cheaper, tin-cure silicone)
· Chopped Carbon Fiber (1 - 6mm max e.g Tenax 2 2lbs for $30) ***
· Rubbing Alcohol
Tools
· Butcher Paper (Lay it down to not get everything sticky)
· Disposable Cups (to mix in)
· Multimeter
· Mixing Stick (This stainless steel spatula from mcmaster is my favorite for silicone)
· (optional) Conductivity Testing Mixer (Make Your Own in Later Steps)
Process
1) Mix a small spoonful of chopped carbon fiber with a splash of rubbing alcohol. (just enough to get it wet)
2) Disperse the hairs. Stir it up real good, the alcohol will break apart all the little hairs, you can see them separate.
3) Let the alcohol evaporate
4) Add some of your dispersed carbon hairs to a cup of your Part A Silicone Mixture Goo
5) Mix REALLY WELL. Test the conductivity every-now-and-then to see when the mixture gets conductive. If you are mixing well, the goo should be gray with a metallic silver sheen.
6) Add Part B and Mix well again!
***Remember to use basic safety precautions when handling carbon fiber. The fibers themselves are non-toxic, but can be bad for you if loose ones get in your eyes or lungs. Wear a facemask when mixing up dry carbon fibers. More carbon fiber safety info here: http://www.protechcomposites.com/pages/Working-Wit...
Step 2: Make Conductive Rubber Wires
A useful item to have when making silicone circuits is conductive bits extruded into long thin wires. You can leave them bare, or dunk them in some regular silicone to make insulated wire (just like regular wires). To make them, you squeeze silicone through a caulk gun, into a small tube. Let it cure in the tube, and pull it out! It's a fun conductive noodle!
To make insulated wires, dip into non-conductive silicone and let cure.
Step 3: Load Into Breadboard Shape
I had to split my conductive wires in half (because my tubing was too large) in order to get the proper spacing of a regular breadboard.
When you have these insulated bits, load them up tightly next to each other in some sort of container to hold them together (i found a nice box). I used NON-CONDUCTIVE rubber bits to create the gaps splitting areas of a traditional breadboard.
After everything is in place, just pour some silicone on top to pot everything together!
Step 4: Wire Up Your Circuits!
It's real easy! Just poke wires into areas next to each other!
Step 5: Future Versions
Future versions might let us do this much easier, and just create a shape that we can load the conductive silicone into.
My first attempt to cast the silicone directly into a breadboard did not work because of the tiny areas involved. If I want to cast such small bits directly, I probably need to source a smaller length of chopped Carbon Fiber (like 1mm). http://www.tohotenaxamerica.com/shortfibers.php
Rainy Day Challenge
Rainy Day Challenge
Full Spectrum Laser Contest 2016
Digital Life 101 Challenge
2 People Made This Project!
  • Potato Speed Challenge
  • Bikes Challenge
    Bikes Challenge
  • Remix Contest
    Remix Contest
15 Discussions
dmorais
dmorais
4 years ago
Hey blorgggg - very cool, can i ask where you got the silicone rubber for the mold?
blorgggg
blorgggg
Reply 4 years ago
Smooth-on
blorgggg
blorgggg
Reply 4 years ago
Smooth-on
StuartB44
StuartB44
4 years ago
How are the pins on an I.C. not shorted together. There does'nt appear to be any thing between them to isolate them from each other. Pins 1 to 4 should all be shorted together, and pins 5 to 8 should be.
blorgggg
blorgggg
Reply 4 years ago
The pins on the IC are connected to a series of parallel series of insulated connectors (just like in a regular breadboard). They are made from thin tubes of conductive silicone that are dunked in a thin layer of non-conductive silicone to insulate them :)
kloopk
kloopk
4 years ago
perhaps graphite powder rather than the carbon fibres would work for smaller conductive areas. that should mix well with the silicone
blorgggg
blorgggg
Reply 4 years ago
Hahha nope, you should check out the main instructable about silicone circuits for an explanation of why the carbon power doesn't work with nice silicone https://www.instructables.com/id/Silc-Circuits-High-Performance-Conductive-Silicone/
kloopk
kloopk
Reply 4 years ago
cool thanks for opening my eyes to that, I was looking in to making some conductive silicone and was looking down the graphite route, you have saved me some time cheers
Plusea
Plusea
4 years ago
This is amazing!
blorgggg
blorgggg
Reply 4 years ago
I forget if I showed you the rubber speaker too! (Terrible video demo, but you get the idea) :)
https://www.youtube.com/watch?v=jxVEDlJj25Q
EToft
EToft
4 years ago
I like this idea in general, and have an idea...at least for anyone with a 3d printer. Print the breadboard "frame"...mix the conductive silicone...coat the frame with the silicon to pack/fill the rails, and wipe off the excess. Now you have nice evenly spaced rails, and the plastic frame insulates the rails from each other, provides structure and separates the target rails. One step further...color code the rails...alternating colors could make building circuits easier for old guys like me with sight issues.
blorgggg
blorgggg
Reply 4 years ago
Great idea!
chuckstake
chuckstake
4 years ago
do like for finish circuit
onion2
onion2
4 years ago
omg it's so fun :O
