Introduction: Ruberband Gun
This Instructable will show you how to make a Ruberband gun that shoots a small watch battery, plastic pellets, and cut up pencil erasers up to 35 to 40 feet. DO NOT AIM AT FACE!!!!
Step 1: You Will Need:
you will need:
" a paperclip
" a hot glue gun
" a big thread spool
" a little thread spool (make sure that the hole in both spools are 9 mm around or bigger)
" double sided foam tape
" Ruberband
Step 2:
first unbend the first section of the paperclip like so in the picture.
Step 3:
Clip the ruberband to the paper clip like in the picture.
Step 4:
Thread the paperclip with ruberband through the center hole of the big spool.
Step 5:
stretch the ruberband and come over and hook it on to the other side of the spool by pulling on the straight end of the paperclip.
Step 6:
Bend straight end of paperclip down like in the picture.
Step 7:
Stick two small pieces of double sided foam tape on each side of the ruberband.
Step 8:
Using the hot glue gun glue the small spool to the foam tape this will be your barrel. let it dry and your done. It's a recycled gun.
Step 9: Firing the Gun
to firing the gun place the ammo in the top of the barrel pull back the paperclip and let go. DO NOT AIM AT FACE!!!!!
Step 10:
If you want you can put tape on the back three side holes so you can store ammo in it.
