Rubik's Cube Style Pincushion
Intro: Rubik's Cube Style Pincushion
All sewers need a place to keep their pins. Why use one of those dull, boring store bought tomato pincushions when you can have something with a bit more pizazz. Remember the hours (or days/weeks) trying to get your Rubik's cube back to its original pattern? Now you can have one that is always "done". Use it as a pincushion or just as a fun plushie....either way, it will become a topic of conversation.
This pincushion can be purchased here as part of the Sewuseful contest:
http://www.etsy.com/view_listing.php?listing_id=6413900
STEP 1: Gather Supplies
For this pincushion you will need:
1 9" X 12" sheet of black craft felt
1 9" X 12" sheet of blue craft felt
1 9" X 12" sheet of yellow craft felt
1 9" X 12" sheet of white craft felt
1 9" X 12" sheet of orange craft felt
1 9" X 12" sheet of green craft felt
You will use most of the sheet of black felt, but only a very small strip from each color. If you have scraps of the colors, you will be fine.
poly-fil stuffing (or stuffing of choice)
glue stick, or craft glue
scissors or rotary cutter with cutting mat
matching thread or embroidery floss
ruler
pins
usual sewing supplies
ruler
pins
STEP 2: Black Squares
You will need to cut six 2.5" squares from the black felt. I used a rotary cutter (and self healing mat) with an acrylic quilter's ruler for this step. These pieces will be the "background" for each color. If you look at the traditional Rubik's cube, you will see that each square has a black border around them. I recommend cutting each square separately, because felt has a tendency to slide around if you stack too many layers for cutting.
STEP 3: Cutting Color Pieces Part 1
Each colored square in my pincushion measure .5". If you would like there to be less of the black border showing, increase this measurement accordingly.
First cut one .5" strip from your first color choice. You will be cutting out 9 .5" squares from each color. If you are using a full sheet of felt, you can cut it from either the long side or the shorter side. I chose the longer side to guarantee that I would a long enough strip.
STEP 4: Cutting Color Pieces Step 2
Take each colored strip that you cut from step 3 and cut 9 .5" squares. Save the remainder for another project.
STEP 5: Attaching Colored Squares
Now you will be attaching the colored squares to the black backgrounds. At this time, you can choose to have all one color on each side or mix the colors up.
Depending on your comfort level, you can choose to hand sew or machine sew the little squares on. I chose to hand sew mine. You can either pin each square in place or use some form of glue. A glue stick will hold the pieces in place nicely until you can hand sew them in place. If you choose to use a craft glue, be very careful not to use too much. When these types of glue dry, they usually make it very difficult to push the pins through. Sewing can be frustrating enough without the extra aggravation of a non-functioning pincushion.
I used matching sewing thread to stitch each color piece down. I generally placed three stitches on each side of color piece. If you decide to use a sewing machine, I recommend using invisible thread.
STEP 6: Begin Stitching Panels Together
After all color pieces are stitched into place, you will begin stitching the side panels together.
I used my daughter's (16) mixed cube as a reference for color placement. You may decide to piece yours together in any order you wish.
I used white as my top piece since it has the Rubik's logo on the center square. I then sewed my next panel on. I chose to use green next. Holding wrong sides together, using a whip stitch, sew one edge of the green to one matching edge of the white.
STEP 7: Adding Next Side Panel
Now you will continue to add a new side panel. This time I added the red panel.
When you stitch this panel on, you will be stitching it to the white and green panel. Beginning at the bottom corner of the green panel, start whip stitching the red and green panels together. When you cone to the end of this side, continue to attach the red panel to the white panel.
STEP 8: Orange Panel
Now you will attach the orange panel in the same manner as the others.
This panel will have the white panel on top and the green panel to its right side. It is directly across from the red panel.
Stitch the seam where the orange meets the white and also where the green panel comes in contact with the orange.
STEP 9: Blue Panel
Next, attach the blue panel to the forming cube.
The blue panel will touch the white panel on top, the red panel to the left, and the orange panel on the right.
Attach in the same manner as other panels. For this panel, you will be sewing three sides of the blue panel. The bottom (when you have the white as the top) portion will not be sewn...yet.
STEP 10: Adding Final Panel and Stuffing
Now you will attach the final panel.
In this example, the yellow panel is the bottom of the cube. When you attach this panel, you will be stitching three of the four sides. The fourth side will be left open for ease of stuffing the pin cushion.
Now you can stuff your cube. Stuff firmly, but do not over stuff. Over stuffing will cause the sides to bulge. Some bulging will occur naturally though. Just stuff it until you are happy with the results.
STEP 11: Finished!!
Sew the last side closed. Bury your thread end inside the cube.
Stick some pins in it and you are DONE ! Congratulations you now have a new "toy" for your sewing area or desk.
20 Comments
kP 16 years ago
m1ss1ontomars2k4 16 years ago
kP 14 years ago
HannahBananaa19 14 years ago
rsislandcrafts 14 years ago
knex_mepalm 14 years ago
cutekitten 15 years ago
get to da parakeet 15 years ago
spacegirl94 15 years ago
lukethebook333 15 years ago
rsislandcrafts 15 years ago
kwilh 15 years ago
Eruaphadriel 15 years ago
Siebe 15 years ago
ahavajora 15 years ago
GorillazMiko 16 years ago
rsislandcrafts 16 years ago
andy60 16 years ago
crafty carolinagirl 16 years ago
