Run a Drill Off a Car Battery
Intro: Run a Drill Off a Car Battery
Here is a quick way to recycle and reuse that old battery-powered drill with the dead or missing battery. Just wire it up to work off a car battery.
I seem to have portable drills that have battery packs that eventually fail. Sometimes I can get replacement battery packs but sometimes I can't. I have seen workable drills with bad batteries at yard sales for just a few dollars. Recycle and reuse them.
In the example I show here I actually bought these cheap drills for the battery packs and chargers so I had the drills but no batteries.
Almost any drill powered by 9 VDC to 18 VDC battery packs can run off a car battery. Just add a convenient length of low voltage wire and a couple of battery clips and you have a handy recycled drill to use anywhere there is a 12 volt battery. I carry one in my car and have another one in my boat.
Some soldering is required but the whole project shouldn't take more than about 30 minutes.
Obviously I should have searched Instructables before I published this. There are already a number of IBLs you can find by searching "12 volt drill". So now there is one more. (:
STEP 1: Tools and Parts
Soldering iron
Electrical solder
Drill
Wire stripper
Drill with dead or missing battery pack
Landscape low-voltage 16/2 wire (Lowes #210913, 50', enough for 2-5 drills) $13
Battery clips (Lowes #29745) $3
Electrical solder
Drill
Wire stripper
STEP 2: Connect Wire to Drill
Note: If you have a dead battery pack with your drill you can remove the old cells and run the wire to the contacts of the battery pack. This may be a lot easier than trying to get up in the drill handle to solder directly to the contacts there.
I didn't have the battery so I wired directly to the contacts in the base of the drill.
Decide on how long you want your cord to be. I have found a 10' length of wire is a good general-use length. If you want to be able to reach any place around the opposite end of your car or boat then measure out what you need to reach back to the battery.
- Drill two side-by-side 3/16" holes for wire to enter the base.
- Run the wire through oval hole into the battery pack or the drill base.
- Strip the ends of wire and tin them.
- Clean and tin the contacts in the drill base where the wires will attach.
- Solder the wires to the contacts.
- Tape over the base or reassemble the old battery case.
STEP 3: Add Battery Clips
- Separate the free ends of the wire for about 6".
- Tie an electrician's knot (Pic 2) at the end of the split.
- Strip and tin the wire ends.
- Solder on the battery clips.
Note: It really doesn't matter which wire is red and which wire is black. You will just change the direction switch on the drill to go forward or reverse.
STEP 4: Some Uses
In a car: buffer polish pad, drill mounting holes for switches and accessories, an electric screw driver.
In a truck: socket wrench with quick connect drill adapter, fence repair out in the field, portable paint stirrer.
In a boat: All kinds of drilling and polishing without any shock hazard from shore power and no battery to keep charged.
Now you have a drill that is easy to store, light and never has a dead battery!
16 Comments
russ_hensel 6 years ago
Just a note to let you know I have added this to the collection: Cordless Drill Repair - Add a Cord !
>> https://www.instructables.com/id/Cordless-Drill-Re...
Take a look at a bunch of different/similar approaches to this project.
If you want to fix the battery see:
>> https://www.instructables.com/id/Cordless-Drill-Ba...
lousiezhang 6 years ago
Thank you for the instructable. We selling replacement battery for Cordless Tools on loopower.
PowerP 8 years ago
Hi, Guys, check this plug converter, they made it very easy to use for drill, and any kind of tool to replace battery.
http://www.findpowercord.com/use-ex-one-converter-...
http://www.findpowercord.com/18v-power-supply-and-ex-one-converter-package-to-ryobi-cordless-tools/
dentinas 9 years ago
that was easy to make, thanks for the instructable ;)
Kes
jimmyf 11 years ago
rotemoss 11 years ago
What is the typical effect from a drill? I will connect my drill via a fuse, so I need to know if 15A would be enough.
steam_cannon 11 years ago
omnibot 11 years ago
captainj954 11 years ago
https://www.instructables.com/answers/I-want-to-run-my-12-volt-power-tools-ridgid-us/C4KZHUIH9T4IGFG
slotdoc 11 years ago
ruanbosman 11 years ago
Bill WW 11 years ago
Yep, I keep a 12V battery in my shop, also drills w/o battery packs under the workbench. Will power them up today!
Bill
pinhead1984 11 years ago
A small note regarding your voltage range on drills that you can do this mod to: 12v would over power a 9v drill and under power an 18v drill.
I also tried this mod on my 18v and was disappointed in the large loss of torque (torque output was equal to a 6-9v drill, pretty gutless).
Beyond that, nice 'ible.
blkhawk 11 years ago
bikeframe 11 years ago
Thanks for comment. I debated whether to mention a cig plug as an option. I am pretty sure the drill would draw less current than the cig lighter coil so it should work OK.
You could use a two-wire flat connector and make a battery clip ending like I showed and a cig plug ending like you suggest. That would cover all situations.
Fred
